First CEL light in 2800 miles. It came on with heavy acceleration passing (safely of course) as I was on an incline. Got home after a long drive and then restarted the car 3 times and now no engine light. Good thing since I couldn’t get into service for a week out so may or may not go but curious as to what would cause this. This should not be unusual and not in Race mode but the QV can handle speed very well and I have given it way more juice but typically roll into in and this was more of a floor it. If it doesn’t pop up again in the next week I will probably pass on the appointment since the whole REBOOT 3 times rule seemed to do the trick. Did it just get overloaded and caused the CEL. It stayed on the whole rest of the trip until I got home.
Thoughts? Tank was full just FYI.
I have a Q4 but my car seems to have settled into a pattern:
Hold it floored for an extended time to pass on a incline. Speed will get crazy if this is done on the level.
Suddenly release the accelerator (pass completed, etc).
Immediate dashboard light up.
The important next step is:
Hookup Multiecuscan (or other OBDII reader) and read the code. Write it down. Clear the error.
Of course you need to plan ahead and get the reader before the problem happens.
In my case I got error P0039, which most likely indicates that the turbo intake bypass valve is sticking; perhaps only at full boost and max temperature. This is the same valve that Go Fast Bits makes a good profit selling better fabricated valve bodies mostly to address exactly this issue.
Still working with EuroCompulsion to get a valve that fits Giulia 2.0T...
Before anyone yells at me regarding having the car serviced: I did take it in earlier this week, but the company told me that I need to put the stock intake back on before they can do this as a warranty repair. So it waits until the next time I bring it in...
