Just noticed that Squadra Tuning in The Netherlands can now access race mode on non-QV cars, see
Squadra race mode
Squadra race mode
In byte 88 you have AC So it should works.Ok here is the untouched bytes screen, 2017 giulia ti rwd usa market, guess we have different numeration
@kozak - you have a car without active suspension, correct?Understood, but not the point. Install the wrong switch and there may be malfunctions of the suspension system. I see that Giulia QV appears to have active suspension standard and the RDNA switch only comes on the QV, so your statement is correct. However, if someone installs such a switch in a car that lacks the active suspension what happens if the suspension button is pushed by accident or intention?
Yes, i dont have active suspension.@kozak - you have a car without active suspension, correct?
Can you answer his question?
Ok - so what happens if you push the "suspension"-button?Yes, i dont have active suspension.
Nothing [emoji4]Ok - so what happens if you push the "suspension"-button?
So what you meant is to modify byte number 88 (decimal) counting from 0. I think most forum members thought you meant to find the byte sequence 0x88 0xac, then modify the byte with 0xac.In byte 88 you have AC So it should works.
Look at proxi in multiecusan and than write please...So what you meant is to modify byte number 88 (decimal) counting from 0. I think most forum members thought you meant to find the byte sequence 0x88 0xac, then modify the byte with 0xac.
no, counting from 1, MES for some odd reason counts from 1 in oppose to industry standard in all electronic/software and real addressing. to confuse things more, MES shows byte 0 before you touch coursor so you may think it counts from 0 the first byte.So what you meant is to modify byte number 88 (decimal) counting from 0. I think most forum members thought you meant to find the byte sequence 0x88 0xac, then modify the byte with 0xac.
Great, So another giulia with race mode [emoji106][emoji41]Hy Alfisti!
I have a Giulia Veloce Q4 2.0 280PS produced on March 2018. I bought the DNA-Race stud, cost 100€ in Austria, partnumber is: 156 129 321.
I changed the Byte 88 from AC to CC, proxy alignment, recalibrated the ABS Module and now i have the RACE Mode. The transmission in racemode is even faster, the throttle also. ESC is OFF and i am able to do donuts![]()
Only the shift indicator does not work. i think it is because the 2.0 does not rev as high as the Quadrifoglio.
Yes, in both i got.@kozak Your switch has adaptive suspension buttons on top? And im going through the pictures looking for needed resistors lol
Between pin 5 and 6Well first ill just try to install 3rd switch and see if it works, if not ill be adding resistors one by one around the switch
This is great! Thank you! Will help so muchBetween pin 5 and 6
A- 1,32 kohm
N- 523 ohm
D- 236 ohm
R- 90,8 ohm
Would it be possible for you to do a write up on this? With screen shots etc? Might be helpful.no, counting from 1, MES for some odd reason counts from 1 in oppose to industry standard in all electronic/software and real addressing. to confuse things more, MES shows byte 0 before you touch coursor so you may think it counts from 0 the first byte.
regarding race mode, got it activated the same way week ago in my giulia, works fine.
He does it the same Way as i wrote.Would it be possible for you to do a write up on this? With screen shots etc? Might be helpful.
exactly, it is info i got from my fellow buddy kozak last weekHe does it the same Way as i wrote.
