This topic has been beaten to death, but I didn't see anyone do a writeup. There is an updated part from Alfa for this and my dealer was charging $62.99 (Stuart, FL Alfa Romeo). I also purchased a rear sunshade as mine was getting hung up which was $339.99 for grey (beige was $386.99). Didn't want to pull the headliner twice so it made sense. The parts guy there was pretty cool and super helpful. He stated that they do 2-3 a week and didn't need to look up the part if that tells you anything. They also gave me a free shirt which was pretty nice as well. 10/10 for Alfa of Stuart so far.
I had the typical failure as seen below where the plastic end had cracked allowing the knurled tube end to come loose. The sunroof was closed along with the sunshade (I bought it that way). Only the close button worked and resulted in the motor spinning indefinitely with no movement.
A few tips
A few tips
- Keep the sunroof closed to make the cable shorter and easier to deal with.
- Leave the glass in to avoid having to adjust it (wind noise)
- Keep you hands clean (and tools for that matter)
- Don't crease/bend the headliner
- Beer helps
- Here you can see the difference in the tubes from a '18 Q4 and the replacement part
- How the tube should look (minus the crack - I pushed it together for the photo)
- How the tube looked on both sides
- Remove visors and disconnect wiring for vanity light.
- Tabs conceal the screws that hold these in.
- Pull the seat bottom out by lifting the front edge of the seat (under where your knees would bend) and pulling it towards the fron of the car.
- Unbolt the lower seat belts to feed through the holes in the seat cushion.
- Place seat to the side and make sure your keep track of the order of the washers on the seat belt bolt.
- Bolt hole for the seat shown here. (Ignore the sweat on my seats, it was 100+ in the garage and 150% humidity)
- You'll be pulling the side cushions for the backrest out now (the sweating part)
