41 - 60 of 92 Posts
I ordered the part below and will try it out.
This must be what we need.
time delay timer (momentary, on/off cycle that could be set from .15 sec to many hours,...)
Will post instructions and video once I get it done.
If ever you find the pictures of the switch pin out and intructions to access the light switch in the meantime, it will be greatly appreciated.
https://www.amazon.ca/gp/product/B00PD65UGA/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
this with a relay might work, a momentary pulse- relay closes (connecting to ground)- pulse is over-relay opens
Reactions: Verrilli
alright guys,
did a simple test:
while you hit the engine start button on the steering wheel and the starter motor turns, just hit the s/s button. the little light stays on and s/s disengages.
therefore,
a simple 12v automotive relay will do the trick!:
85= ground
86= 12v+ from starter wire
30= ground
87= pin#8 on s/s switch.
switch will still be functional in case you'd like to activate start/stop feature during your drive.
Appolon,
Sounds good if you can locate the +12 from the starter. Other solutions only require local signals.
I don't have a problem with the pushing the button as we have it now, which I do pretty much daily, but what annoys me the most is that when the system is engaged and you stop in your driveway, you don't get a chance to put the trans in park. Engine shuts off, click on park, engine turns, than shut-off
At a minimum, a delay of a second or two would be nice
Hey guys, considering buying a Stelvio, and the s/s system is one of the most annoying things I experienced in it, especially when moving from dynamic to natural it reenables itself! Would an OBD register approach make sense? Has anyone tried it?
Sent from my BBB100-2 using Tapatalk
Concur 100%. Maybe even 2 or 3 seconds of delay?
There is an easy solution - stay in dynamic mode.
I have never noticed this happening in the rare times I switch to N in My Giulia QV. I just tried it sitting in the driveway and moving to N mode did not turn off the start/stop light on the switch.
Jeff
Interesting. In the Stelvio everytime moving from N to D it reactivates the S/S. Also when switching on the car after leaving it on Dynamic it also reactivates it. Maybe the case with the Giulia is different. On another note I really loved the Guilia, the interior finish is way superior to Stelvio, but I need an SUV, so Giulia is out of the question unfortunately..
I think that's conform the Giulia. Switching off S/S is not permanent, every time you start the car the S/S is re-enabled till you switch it off again (for the current trip). That's what makes it anoying, it does not remember the last setting.
alright guys,
did a simple test:
therefore,
85= ground
30= ground
I agree since starter 12v is temporary, you won't get error for stuck SS switch.
Since the engine computer is in the engine bay, you would probably have to tap the starter and mount relay in engine bay and run a wire to pin 8 on the SS switch. Also hide the wiring, but most likely if found would void warranty.
re Auto Stop/Start...as far as I can tell, all appropriate conditions are met (as listed in the UM), but still mostly inoperative.
didn't work Sunday; did Saturday; didn't Tuesday-Friday...
Service for headlight washer issue and more last week showed no faults.
Did work on the trip to service (Monday); didn't on return (later same day)...
Service guy said " don't worry; be happy".
In my opinion, this 'feature' is not only annoying, but could prove to be dangerous.
Earlier this week, starting my commute to work, I came to a stop at a junction from a residential street, out on to a major street. I'd angled the car slightly, to make the right turn. I was looking to my left to see if the street was clear. At the moment that I decided it was safe to pull out, the engine cut out, via the Stop/Start feature. The steering went heavy, as expected when the engine is turned off, and tried to center slightly! As I lifted my foot off the brake, the engine started up, and I was able to pull out. This process seemed unsettling, as the steering wheel jerked slightly, right when I was ready to pull out onto a major street.
I'm not sure why pushing the stop/start defeat button is any more difficult than pushing the button on the steering wheel that brings the engine to life.
41 - 60 of 92 Posts
