Any thoughts on if either filter is better then the other?
Am thinking about pairing it with my X-Pipe
Oh I have zero concern over the air filter causing engine failure or premature wear. I am perfectly content with how clean the intake is with the Sprint after 3000 miles of driving with it in. In my mind using a high flow filter is low risk to no risk with proper maintenance. I also did not grab any baseline photos before putting the Sprint filter in so I was hoping another member could. My goal is to document my experience with it should there exist people on the ropes about whether or not to buy one.Not sure why you guys are so worried about minute particals entering your engine. You do know that when a brand new engine goes through a break in period there are thousands of metal shrouds there get grinded within the engine compartment and engine parts get smoothed over. I’ve never seen an air filter be the death of an engine.
Hello Blazin,Also, left a voice mail to @MADNESS Autoworks and email with no response 2 weeks now. Garbage.
I am worried because:Not sure why you guys are so worried about minute particals entering your engine. You do know that when a brand new engine goes through a break in period there are thousands of metal shrouds there get grinded within the engine compartment and engine parts get smoothed over. I’ve never seen an air filter be the death of an engine.
I've run a high flow air filter in all of my turbo charged cars and maybe Ive been lucky or maybe it's because I've proper cleaned them at routine service intervals but my wife's 2015 WRX is approaching 100k miles and the motor and turbo are running strong. It has a K&N. Before that my 2012 Mazdaspeed 3 had a K&N high flow air filter in it and before it was totaled from being rear ended into another car around 60k miles it never skipped a beat.I am worried because:
All of the above combined leads to long term reduced performance and greater chance of valve deposits falling in the cylinder and then going through the turbo hot side, possibly doing some damage and then sticking on the CAT. again dropping performance.
- particles stick to the MAF, which leads to incorrect readings about flow and air temp - reducing performance. Cleaning the MAF = 20% chance of it failing (personal exp)
- particles stick to cold side of the trubo. Crankcase ventilation is before cold side, so dust and oil sticks very well to metal parts. This unbalances the turbo at 180k-200k = increased wear on the bearings, reduced performance.
- particles stick to MAP, throttle body and most important to valves. This increases the deposits from the already prone to carbon deposits direct injected engine = decreased performance.
So what is the point of gaining a few hp (if any) and certainly loosing performance and reliability long term?
