Just noticed that Squadra Tuning in The Netherlands can now access race mode on non-QV cars, see
Squadra race mode
Squadra race mode
I already did that and it didn't work.One byte is AC, change to CC and Look
I don't think that link refers to the DNA knob.....Anyone have instructions on pulling the DNA switch?
Edit: here it is https://inkocraft.weebly.com/center-console-dismantling.html
I must have missed the post you mentioned with 4 switches. But not necessarily, default with no switches pressed is one mode already. So 3 switches for 4 mode is OK.@1mk1 - I saw that but also saw one with 4 switches? Don't we need 4 switches? DNA + R is 4 modes!
I had to remove the center console compartment top surround too. The gearlever surround is block by it on the lower (rear) part. So rear vents, armrest, and compartment surround all have to come off to remove the gearlever surround. I found that by using your fingers, it is easier to work loose the front side (cup holder end) first. Then slowing work your way to loose all other taps from Front to Rear.I don't think that link refers to the DNA knob.....
afaik, all you need to do is remove the gearlever surround using plastic tools, it's only clipped in. Then remove the DNA knob, fixed by screws from below.
could be wrong though, haven't tried it myself![]()
This is very good, i havent seen a switch yet with 2 switches and dampener setting, gives more info on resistors and whats needed, thanks!
A mode is no switches pressed@1mk1 - I saw that but also saw one with 4 switches? Don't we need 4 switches? DNA + R is 4 modes!
Nope, i had the switch apart and connected, checked which switch does what. A mode all switches offI think its different.
A mode 0 switch pressed
N mode 1 switch pressed
D mode 2 switches pressed
R mode 3 switches pressed at the same time.
So breaking the knob means you’re stuck in A mode. Scary thought!Nope, i had the switch apart and connected, checked which switch does what. A mode all switches off
Other modes have separate switches
Yes pretty much lol, then you just disconnect the switch and it goes to N mode which is not that scary hahaSo breaking the knob means you’re stuck in A mode. Scary thought!
So I have a 2017 Giulia Q4 built in December of 2016, I changed 88 AC -> CC in multiECUscan and it fails to complete a proxi align, it says drivetrain out of range and then the odometer flashes, so the only way I can get the car working again is to switch 88 CC back to 88 AC and then do the 3 configs with the contiABS system.Each line in the window is 24 pairs, find the 4th line, 16th position should be AC, change to CC.
Hello, guys.So I have a 2017 Giulia Q4 built in December of 2016, I changed 88 AC -> CC in multiECUscan and it fails to complete a proxi align, it says drivetrain out of range and then the odometer flashes, so the only way I can get the car working again is to switch 88 CC back to 88 AC and then do the 3 configs with the contiABS system.
Any ideas why this will not work?
Yeah I know didn't work
What region? Is good to understand all of the details. I have a 2018 North America that had no problems with the #88 proxi change.Hello, guys.
Read it here for days.
Got the same problem as you !
I converted my original DNA knob.
but if i try to make the proxy is the same error of beta2alfa.
I have a Giulia Veloce 2.0T build in late 2016 with Performance package.
