141 - 160 of 1,111 Posts
Pick a high gear (4, 5, 6), start from 1.5-2k rpm and floor it until redline.
Since MES doesn't record that fast you basically need to try to get as many readings as possible.
Cool thanks. I have previously used Torque pro using BT dongle for measuring boost, only issue is Torque seems to cap boost measurement.
I will be using the Multiplex via USB cable and try and set it max refresh rate.
Reactions: stocki
Can someone make logs of stock?
My stock is 200hp version so of not much use. Maybe someone else could?
I just flashed back to mod file last week. I will log the stock one next time I flash it..as it is a pain to flash back and clear all the errors using the handheld. I know my 200hp is only software limited and in stock form max boost I have seen is 18psig. Using Torque pro with the mod file, I am seeing 22.5 psig which seems quite low for a 325hp tune, compared to what others are seeing on their modified 280hp. I will log with MES and see what I get.
In case anyone can make use of it:
Here are two logs.
EC P2 (stock exhaust detuned), EC V1, Sprint Filter, GFB DV+
Can you do a higher gear like 5th? Be good to see as much load on there as possible
Very interesting no timing advance at all under wot just like stock.
Looks like it spikes almost 28psi boost down low and tapers to 20psi at redline. Pretty similar to stock but with a bit more low end.
Will do.
I'm not sure that we can trust MES with the timing readouts. Looks weird to me - but I'm no expert.
It can be truth that there is not enough fuel to get more hp. Or sth in ecm is cutting boost in high range.
It looks likethe tubo size is the limit to me. I can offset as much as i want with jb4 and when i request too much up top i just get limp mode and wastegate code. Thats coomon to when you request more than turbo can do. No lean codes. No fp issues. Also the nice thing about jb4 is the ecu doesnt see the added boost so any torque limiters get effectively bypassed since the ecu thinks its making less power than stock.
Which is post cooler? I dont see it logged.
wgdc is at ~50 at high Rpm so boost limited by tune.. use the link i posted its easy and interactive.
I am finding this thread extremely interesting and coming from the engineering profession validation by data gathering is the best way to learn. Just trying to understand what WGDC means and I found this article quite educational. I know our cars have a electrically controlled wastegate commanded by the ECM. I am probably the least experienced in all this here so keep it coming guys. Need to polish my grey cells.
Reactions: Jackson
Im begging terry at bms now to see if he can do a harness and map for wastegate control
Wgdc is wastegate duty cycle
