Giulia or Stelvio with gas engines use coolant bleeding plugs made of recycled plastic, which are prone to heat and coolant deterioration, causing them to fail, and to release coolant fluid in the engine compartment.
See install pics of USA quality Alfissimo aluminum plug up against the firewall.
Remove plastic plug and rubber gasket, replace with Alfissimo Al plug and o-ring.
Start with an 8 mm, end with a 10 mm.
