How to replace O ring?
17K views 5 replies 5 participants last post by  fast_dave
Anyone know how to replace the turbo o rings on a 2.0? Dealer told me mine needs to be replaced but it’s 500 miles anyway. Anyone know if it’s easy and/or how to do it
#2 ·
Mine had to be replaced at 22000 miles and again at 41000 miles. I also have a 2017. I can't answer your question but if you don't go the DIY route you might be able to take it to a jeep dealership. They have a variant of the same engine and from what I understand the O-Ring part is mix and match between jeep and alfa.
Reactions: Glenn
#3 ·
Go down to post #12: Something leaking by turbo
You have to unscrew that one bolt that holds both the coolant inlet and outlet tubes and then you also have to unscrew a hex nut (I think), so that you can maneuver the tubes.
Because the dried coolant kind of acts like a glue, you might need to pull on the tubes hard to get them out...
I stole the below photos from a couple of different forum users. I circled in yellow the one bolt and the one nut that need to be removed.
#4 ·
Here's a pack of four (4) Part Number 6833 8389 AA Turbo Coolant O-Rings for the 2.0 Liter Engine.
Purchased from AR Walnut Creek Parts Dept.
Note Package Date = 2021/04/26
Approximately $30
Exploded .pdf factory view of Inlet & Outlet Coolant Lines/O-Rings Attached
NOTE: O-Rings are Part #6 in each picture/.pdf
Hope that helps -
#6 · (Edited)
Does anyone have the part number for the oil line O-ring?
@millerc117
Page 19, Post 374 of the linked thread (lots of good info in the ENTIRE thread).
There are (2) Different Oil Line O-Rings, and from the posting it appears that you need Qty (2) of each part number.
* 68374709AA
* 68374710AA
Giulia 2.0l: gottuned Hybrid Turbo with gt2867r wheel...
NOTE: I found out after the fact that Jeep also uses these O Rings.
They're priced much more reasonably at a Jeep Dealership than at A-R Dealership.
