81 - 100 of 1,077 Posts
90% of giulias here (north europe) gives that unsupported ISO code error, but it has not prevent to configure anything. I asked multiecuscan to add year ago these but nothing has happened. I will try Proxy next week so i will tell you does it work or not.
Need a little bit of help here. Followed the OP and all is well. Changed byte 88 to CC and started the proxi alignment. When it asked to insert the blue cable, everything started to fail, kept going and then it asked for the gray, continued to fail. Part of troubleshooting, I went to the ABS module which asks for gray right of way and I get a ELM327 CAN bus error.
I'm using the OP's USB Link: https://www.amazon.com/ScanTool-OBDLink-USB-Professional-Diagnostics/dp/B005ZWM0R4?pldnSite=1
Bought these cables from eBay, not the same as OP: https://www.ebay.com/itm/6-Adapter-diagnostic-cable-set-fiat-alfa-for-Italian-cars/163064233534?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
Any ideas? I was able to execute a variety of things to test with the USB link only and w/out the colored cables, I'm thinking they're faulty?
You may need usb3.0 :oops:
Discussion starter · #83 ·
Any update here? Did anyone order a race knob from Mopar and installed it successfully?
My order is still delayed. I contacted mopar online parts and mentioned the other forum users experience that they had told him the part wasn’t available. They claim the part is still available from mopar but current availability is listed as mid November. I’ll likely be checking with my dealer to see what their availability looks like.
Alfissimo?
Is it a '17 knob or '19? They should be different... latter being a full CAN node..
Alfissimo 16-18 part number 156129321. About 160 USD shipped. What do you get with a full CAN mode? Everything went smooth in my install with the exception of the drive train control module failing during proxi alignment. Still trying to figure that out.
Ok full observations after installing RACE mode:
Car setup: 2.0 Ti US Spec, dampers, awd, MY18 with build date 07/17, RACE Switch part #156129321, changed byte 88 to CC
-EC Tune Phase II (no pops and bangs)
-EC v1 + BMC Air filter
-EC Pedal Pro
-Fabio valved exhaust
-GFB DV+
1. RACE mode does indeed pull the Phase I tune from N
2. Gas pedal is definitely linear and harder than before in ALL modes, the EC Pedal Pro at setting 9 helps a little but not like it was before
3. Dampers in front to go soft and rear to hard in RACE mode, you'll need to remember to switch the dampers when in race mode to mid
4. Traction control off, i'm a bit surprise how much it takes to actually throw the tail around. Had good success on a hard turn shifting from 1st to 2nd at about 5k
5. Shifts are quicker
6. Pedal sifters work fine
7. Shifting indicators in RACE mode don't trigger because of the different red line in the 2.0
8. Got a "drive train control module" failed during proxi alignment, no idea if that will change any of the behaviors noticed above
P.S For those that are interested in the DV+
Where can we see the damper settings, front soft and rear hard? with MES? also have you try EC. If so, do the dampers behave the same with CC? thanks
These cars like to be planted on the road, have to push little extra to get them sideways, limited slip does help, unless you want to smoke one tire like me ahaha
-EC Pedal Pro
-GFB DV+
So what is your tune setup then as far as what tune ends up in what mode. I'm assuming you started with dual mode. D-phase2 , N-phase1. Has anyone contacted Eurocompulsion to see if they can change tune setup with race mode. Thank you
I think my issue might be related to an unsupported ISO code. Sent an email to MES support to add mine, hopefully that does the trick. I have also tried MES versions 4.0 to 4.4 with the same results.
This is the error I get when requested to use gray/blue cables:
Below is what I receive during a full scan:
For those that want more detailed MES instructions, see steps below. My .02 of contribution to this effort :)
did you get this resolved? I had a similar error and it ended up being a short in the elm OBDII connector. There was a short in the usb cable. I got it replaced from the MES vendor I bought it from on eBay. Second one works as expected.
You can tell if this is an issue by the activity lights. when you hit connect within MES you should see lights continuously blinking on the OBDII end. If this isn’t happening it’s likely a bad cable
Phase 2 on D and phase 1 on N. I contacted them and they're still waiting for their race switch.
Yes. ISO error is still there but the problem was related to bad obd cables. I can confirm that the idiagnostic brand works. My new issue is the DTCM (drive train control module) fails during proxi alignment. Everything else is good including the calibrations and race mode works. I will have to deal with the flashing odo until it gets resolved.
Hi Alfisti,
Let me sumerize:
2017 Guilia super 2.2jtd with manual transmition.
With JRace remap. BMC filter.
Stock 88 was A8. We have changed it to CC. Race mode starting to work. Ok. But the other 3 mode were the same pedal and torque limit set. This is normal... Is there a chance to keep the "A" "N" "D" setup and race mode in dynamic setup?
In the aftenoon we will try the EC.
What do you think? My stock was A8. If we try C8 or E8 in bit of 88?
Br
Peter
Have you noticed, multiecuscan new release 4.5 includes (R)DNA button options now directly in then adjustment page. These are not documented but i tested those. Race mode is option 2 and tcs off mode is option 3. Normal is option 1.
