Awesome job! Hope it helps people more than other thread
Manufacturer | C&K |
Series | HDP |
Circuit | SPST-NO |
Switch Function | Off-Mom |
Current Rating (Amps) | 1mA (DC) |
Voltage Rating - DC | 5V |
Actuator Type | Angled Toggle (Detector) |
Mounting Type | Surface Mount, Right Angle |
Termination Style | Gull Wing |
Features | Board Guide |
Pretravel | 0.006" (0.15mm) |
Operating Temperature | -20°C ~ 70°C |
Operating Position | 0.117" (2.96mm) |
Manufacturer | TE Connectivity Passive Product |
Series | RP73P, Holsworthy |
Packaging | Cut Tape (CT) |
Part Status | Active |
Resistance | 147 Ohms |
Tolerance | ±0.1% |
Power (Watts) | 0.25W, 1/4W |
Composition | Thin Film |
Temperature Coefficient | ±25ppm/°C |
Operating Temperature | -55°C ~ 155°C |
Package / Case | 0805 (2012 Metric) |
Supplier Device Package | 0805 |
Size / Dimension | 0.079" L x 0.049" W (2.00mm x 1.25mm) |
Height - Seated (Max) | 0.026" (0.65mm) |
Number of Terminations | 2 |
Yeah, that thread turned into a large mess. Man, I am NOT motivated today. HAHA.Awesome job! Hope it helps people more than other thread
Well heck, you're local to me, I could just do it for you.You are awesome. Waiting for you to gather your strength to finish...
OK! I'm totally in! I'll try to figure out him to pm you.Well heck, you're local to me, I could just do it for you.![]()
I think that may be correct, but I don't want to incorrectly state something I don't have confirmation on. I believe that it's an actual CANBUS node, as apposed to the older passive device. Not sure where to procure said switch though. Dealer?So, am I reading that if I have a 2019 2.0 TI, the RDNA switch is not available? It is a different switch from the previous years? How would I get one?
Yes MY19 need a new one based on CAN bus interface.So, am I reading that if I have a 2019 2.0 TI, the RDNA switch is not available? It is a different switch from the previous years? How would I get one?
It’s only models with the mono static DNA selector that have the DNA selector set up as a CAN node. @MacGeek stated that he believed this change was coming to MY19 vehicles here in the states. I don't think that ever materialized. I do believe the change was made in Europe though.So, am I reading that if I have a 2019 2.0 TI, the RDNA switch is not available? It is a different switch from the previous years? How would I get one?
Race mode works well with paddle shifts on giulia 280 Ti?I think that may be correct, but I don't want to incorrectly state something I don't have confirmation on. I believe that it's an actual CANBUS node, as apposed to the older passive device. Not sure where to procure said switch though. Dealer?
In the mode that I am running in, EC in byte 88 that does not turn on Race mode, the paddles work.Race mode works well with paddle shifts on giulia 280 Ti?
From a QV specific topic somewhere it sounds like that has to do with a software update. Not sure what version.What do you have on the screen in Cluster? When i turn on race mode i got Gear indicator, others got speed, anyone knows how to turn on speed instead of Gear? I got CC in byte 88.
Ok, I will ask dealer to update Cluster instrument. ThanksFrom a QV specific topic somewhere it sounds like that has to do with a software update. Not sure what version.
