61 - 80 of 1,077 Posts
Discussion starter · #61 ·
But does that mean that A is no longer functional as Advanced Efficiency at all if byte 88 is changed to CC or EC? A mode uses different valve timing and different transmission management, it is not just a pedal mapping.
Hmm, some things still function properly, like sailing, with EC or CC in byte 88. I do know that the pedal map feels the same in all modes now with EC in there.
btw, not sure how relevant it is, but I'm getting 30+ MPG in Dynamic mode lately. Not sure what's up with that. Hopefully modifying 88 hasn't neutered my car in all modes. Doesn't feel like it when I tromp on it.
I implemented CC race mode, successfully performing the proxy align, and implemented a temporary super ghetto home made resistor switch to confirm race mode worked on my NAFTA 2.0 Base Q4 Giulia.
I just ordered my R DNA switch here for $96 before shipping:
Hi Clarke, I wondered if you have received the knob and if it works correctly.
Is that an '18 knob? (I know there are like 8 different knobs on mopar..)
Also, does it keep the last position or goes back to "N"?
I don’t have it yet. I think they are getting it shipped from Europe because my order has been in “processing” for a week and a half. I will contact them next week and see if I can get an estimate. I think I saw somewhere online a confirmation that the European number and the “6ME58LXHAA” Mopar number I ordered are equivalent. I will update when I receive it.
I think you will not get the knob from the mopar online.
Thank you for your order. This is an export only part and not something we can get here in the US. We'll have it removed from the site. Your order will be cancelled and your payment voided.
Thanks,
~ Mike"
Next, you will see a white plastic piece in there (pictured below, sorry no action shots). On the top and bottom of it, the black plastic is keeping the white plastic from coming out the bottom (in reference to the above photo). Use a small flat head (standard) screwdriver to pry out the black tabs so the white plastic can come out the bottom along with the rest of the selector. You will need to pull pretty good to overcome the 4 extra retention tabs around the circumference of the dial (see below photo, right hand part).
91066
91067
Damn it! I can't really do it.
Thanks,
~ Mike"
Thanks for the info, when did you place your order?
I ask because of the response below I just received today when I asked about my order status. It's from the same guy. Maybe he didn't notice this is the same part he already told you couldn't be ordered? Maybe I need a backup plan? I just made a new friend at the gym, a parts guy from the dealer... :sneaky:
Thank you for contacting us. Your order is in processing. At least one of the parts ordered was not in stock and had to be ordered in from Mopar. Everything should arrive to us within the next few business days, and your complete order will ship out the same day the last item comes in. Once the order ships you will receive an email with tracking information.
Thanks,
~ Mike"
Reactions: JeFizz
Discussion starter · #68 ·
Looks like you are trying to pry it apart from the outside. I used a very small, thin, flathead screwdriver on the inside between the white plastic and the 2 black clips (one at a time) with some gentle pulling from the knob.
That's exactly what I did too. It works well.
Reactions: Clarkebb
Thanks,
~ Mike"
I placed order on sunday and got response on monday. So quite immediately.
Need a little bit of help here. Followed the OP and all is well. Changed byte 88 to CC and started the proxi alignment. When it asked to insert the blue cable, everything started to fail, kept going and then it asked for the gray, continued to fail. Part of troubleshooting, I went to the ABS module which asks for gray right of way and I get a ELM327 CAN bus error.
I'm using the OP's USB Link: https://www.amazon.com/ScanTool-OBDLink-USB-Professional-Diagnostics/dp/B005ZWM0R4?pldnSite=1
Bought these cables from eBay, not the same as OP: https://www.ebay.com/itm/6-Adapter-diagnostic-cable-set-fiat-alfa-for-Italian-cars/163064233534?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
Any ideas? I was able to execute a variety of things to test with the USB link only and w/out the colored cables, I'm thinking they're faulty?
Are you using a SGW bypass?
Discussion starter · #73 ·
Very good question. It'll fail completely if you do not. Also, you will not have caused any issues because it couldn't write.
If he's using a bypass, from what I've read, the first part will pass, but the latter parts will fail due to SGW bypass design flaw. His experience sounds like just that.
Discussion starter · #75 ·
Also, the standard SGW bypass can only allow writing to the ECM without modifying it first.
Do to have blue and grey adapter to cable?
Yes I do and use them when prompted. I have also tried going straight into ABS as it calls for the gray to see if I can connect and I get the "ELM327 CAN bus error, check your connections".
My car's mfg date is 2017 and do not require a SGW. Tried to trigger a few things as stated in the OP and was successful therefore do not require one.
I was able to change the byte to CC and it stuck. I swapped the RDNA switch afterwords and tried again with the same results. Switching to RACE, drivers dashboard switches to yellow as expected and get a brief yellow splash page with all the nannies turned off in the entertainment screen. My miles to date in the bottom left, keeps flashing on/off, I presume because I need a proxi alignment done and to finish off the three ABS tests.
For what it's worth, I have also tried changing COM ports on the PC with the same results. Rebooting the laptop and uninstalling/installing the USB OBD yielded the same results as well. Googling and browsing MES site hasn't helped either.
Discussion starter · #79 ·
I think my issue might be related to an unsupported ISO code. Sent an email to MES support to add mine, hopefully that does the trick. I have also tried MES versions 4.0 to 4.4 with the same results.
This is the error I get when requested to use gray/blue cables:
91200
Below is what I receive during a full scan:
91201
For those that want more detailed MES instructions, see steps below. My .02 of contribution to this effort :)
91202
