841 - 860 of 1,077 Posts
Not meant in a condescending way, but you do turn the knob all the way, right?
There is a bit of resistance to overcome - you have to turn it quite far against a spring.
You wouldn't be the first one to fall for this...
@stocki you was right!! This is amazing I just didn’t turn it enough.. I don’t know how but that’s exactly the reason 😂 now all works fine 😁
thank you a lot!!
I understand if you change Byte 88 then the ECM is in N mode which effects the throttle.
Does N mode also have different engine map than D?
Meaning is the timing, boost, etc different between the two?
I've tried to do pulls in my stock car in manual mode from the same RPM and doesn't seem like a difference but I haven't tried to use a performance meter either.
Discussion starter · #844 ·
I can't say for certain, but the general consensus is that N is the same as D for engine. Throttle is different. N is linear, whereas D is a more touchy curve.
Hello everyone, did someone fix the issue of non-working shifters in race mode?
Since this week it is possible, Squadra (and Alfissimo) offer tuning of the automatic gearbox ecu.
I asked Squadra specifically if this would enable manual shifting in race mode on the diesel models and he confirmed it does.
Sadly at this moment you need to physically go there to get the tuning
Oooook! It's time to race! :p
Race work perfect, only one error on proxy alignment.... Node Air Bag (NAB/ORC) FAILED! Why????
I not have any issue, no blinking odo, no warnings, if I connect to Airbag ECU I not have errors ecc.. mystery!
check CAN Setup/Proxi alignment screen in MES for Airbag node status is EOL OK/Failed.
Always fail… is strange, on my old MY18 it worked. Now the odometer blink.
What’s the best speed for ftdi driver? Now I have 38400
Edit: I think my elm327 is damaged, the hotter it gets the more mistakes it makes
ELM327 should be set as high speed in MES.
if you suspect it's ELM327 problem due to overheating try this - start doing your proxi alignment, when it says body node was "success" and jumps to another node disconnect your ELM and do not connect it back until it asks for grey adapter.
