In my 2020 Q4, I have everything turned off, set to just the manual fan setting, as a/c is generally not needed in the Seattle area at all. Rarely use it. Some years, nada. The auto setting will turn the a/c on or off if needed (I think). Also if I set the temperature to the lowest setting, that turns on the a/c. As I said above, don't need a/c here worth talking about.
My only complaint about the ventilation in the Giulia is that it doesn't seem to be all that good as compared to say the 164. It takes a long while for warm air to be flushed out, even at speed down the road. The 164 seems to have better airflow in the cabin, unfortunately the 164 fan is always noisier when it is running, even on the low settings, alas.
The Giulia a/c, when it is on, is definitely better.
