Active suspension same on QV and Ti models?
1 reading
8.2K views 15 replies 8 participants last post by  lockem
I have a 19 Ti Sport with the active suspension. Does the Quad have the same suspension setup as the Ti models with the active suspension? just curious.
#2 ·
No. If it is commanded into Race mode (requires hacks) the Ti will malfunction (soft in front, hard in rear) while the QV will work properly. I believe only the programming is different in the control unit.
I would not be surprised if the shocks are different.
#11 · (Edited)
the cdcm module on the quad also controls the front spoiler and torque vectoring on the qv, as well as having one additional setting for the damping in race mode, so it differs from the 2.0 version....
also the remarks on the squadra site specifically address the models that have adaptive damping as option of course
Squadra has a long history (chip)tuning specifically Alfa's, and is usually correct.....
from site:
When the car is equipped with adaptive damping, it appears that it does not understand the Race position. The front dampers are very soft and the rear is much harder than before. A combination that does not work well on the road. With the button in the middle of the DNA + R selector the dampers can be set to a "Mid" position. That still works well. A solution is to mount a control unit of the adaptive dampers of a QV. Then everything works perfectly and gives the Giulia and a very nice spring / damper behavior.
Such a control unit costs 720.- Euro and is supplied EMPTY (= without software). This must be programmed to a QV for the correct software. As you know, we cannot be easily stopped and are able to program the control unit from a non QV to one from a QV. In short, also solved!
However, does it all really matter ? ;)
#12 ·
Squadra has a long history tuning specifically Alfa's, and is usually correct.....
from site:
Although the CDCM provides input to the TVM, it is the TVM (Torque Vectoring Module) that controls torque vectoring on the QV. I do not know if you run the QV version of the CDCM software without a TVM if it will throw an error.
The active aero has 2 modules to control the actuators. I do not know if they have any connection to the CDCM other than power on/off, but I do not think there is anything.
