21 - 40 of 120 Posts
Reactions: Roo
Discussion starter · #23 ·
Nice work beaups, I may try this on my Ti. I don't have LDW, so I am assuming that I could bind it to the right stalk button instead as long as I am not on the Trip page?
Is there a standard OBD2 port in the trunk? I haven't looked.
Well hell, I hadn't considered that there were cars with no buttons there. There aren't that many different buttons that can be picked up on the can-CH bus. I'll do some logging over the next few days and see what other options there might be.
How about button combos? Right stalk button and rear fog light? Both paddles?
@beaups Any luck? Can I do logging using that arduino / shield / adapter setup or is that only intended for the hack?
Discussion starter · #28 ·
I have some logging SW I wrote for the arduino also, but it's a lot easier for something like this to use cantact/canable setup with cantact software. I'll get to it over the next couple days. Options will be limited - most buttons don't trigger any messaging over this particular bus. And those that do, like paddles, have some odd behavior. Not to mention in non NAFTA cars holding paddles and using both paddles trigger actual desired transmission behavior. I'll find a button I'm sure.
I did some testing now on Stelvio 2.0 TB with the help of beaups code.
The result is that it doesnt work.
It works fine in detecting dna modes and sending messages to ESC control, but nth. happens.
Maybe its because it actually doesnt know about race mode, so at first race mode should be enabled.
Discussion starter · #32 ·
What do you mean "nothing happens"? Do you get the ESC off light or? The code doesn't put the car in race mode, it only signals to module to put car in ESC off mode. It looks like that module then signals the instrument cluster over the primary can bus.
My hardware just arrived. I have Stelvio 2.0T EU version. Is there a way to contact you in some messenger (Skype, Viber), so I can get some insight on what to try :)
