41 - 49 of 49 Posts
I only found out recently my QV had it installed when I bought it... Is what you may get when you buy one "as is...".
Im no expert and since I didn't install it it took me about 45 minutes to get it out. Especially rail on the passenger side is a real pain.
I'm glad I took it out, car is much more civil now and you can still catch it... It used to be very edgy of the line in race with the rear coming loose really easy.
Anywho... after reading into it i can't get over the idea that you're constantly tricking the system, even if some boxes trick really good... It may be TUV certified but isn't that just for the materials used? I don't believe you get a certificate for tricking the ECU successfully without compromise to wear and safety.
TUV is for materials and Safety but also function. Seletron is programmed to run in safe parameters.It is not programmed to push those so far to cause major wear and tear. The tricking of the ECU does not cause wear either. You can run these for a long time, the ECU still gets the same exact signal as it normally would. Seletron sends the ECU those same signals so in reality the ECU is running as stock. The Seletron sends the different signals to the different components for the change and again these changes are not huge. Tuning of any kind will place the possibility of a little more wear on the vehicle but seletron does a nice job of keeping that low. This is really no different that the old EPROM chips from the 90's that we use to do. I had a chipped 164S for 22 years. The ECU and components never failed.
Seletron is not a maxed out piggyback system, it is safe for the car and the owner. TUV is there for Quality, Safety and manufacturing so you get the best product available.
This system is also adjustable. Set at level 5 from Seletron, adjustable LOWER and HIGHER. Your boxes as we checked were at 5, half cocaine level. Might have been fun to detune it before removing it to see if there was a level you liked better. But I get removing it. I think the QV is spectacular as is but some want more. ;) Seletron is a great product and safe.
From my understanding and what Seletron states too is that they have a electromagnetic certificate Electromagnetic Compatibility (EMC) Testing
I don't think that's the same as testing the long-term impact it has on your engine.
Like do they dyno a QV in setting 9 for 20k miles? I don't think so.
The engine/platform is still so new FCA is still finding things out:)
Yes. Not what I am stating. I think you are misunderstanding me. What I am stating is the chipboxes could easily put out more power but Seletron makes sure to keep it in a safe range. Yes FCA is still figuring out things, but this is nothing new for any car manufacturer. Some Seletron boxes have been on cars already at 30K and more. From memory Seletron does have a Quad that they have done the testing on. Any modification, any, can put things a risk. If you are going to might as well go with something that does not push the parameters to the max.
All good, I get what you're saying and at the end of the day car owners should do whatever they want and weigh the risks as best they can.
And I bet these engines are factory tuned very conservative so there's room to play.
Some FB user had 420+ WHP with only external upgrades. Turbo melted itself. Internals seem to be fairly stout though.
I didn't want to lengthen the original post even more, but I took my QV to the track on Monday. Holy @#$#, so much fun! I switched out my wheels to my Nitto NT05s and went to Pacific Raceways in Kent, WA for the Proformance HPDE course. After spending the morning in class and doing some evasive/braking maneuvers and slalom, we spent the afternoon lapping with an instructor in the passenger seat. This was my first time on a track, so I'm definitely a novice, but the QV was fantastic. Given my limited experience, I wasn't pushing her even close to her limits, but man what a rush. Running up to 130mph on the straightaway, then standing on the brakes into a turn, then rolling back onto the throttle, then the crazy G-forces around the turns, it was all awesome. I know some other members with much more driving ability and track experience have said the stock setup on the QVs isn't ideal for track use, but I had so much fun. I've never driven any car like that, that hard for that long, and she behaved just fine. No warning lights or limp mode, no overheating, tires (not stock admittedly) were great. Smelled like burning brakes afterwards, of course, but I checked on the pads and rotors and everything is A-OK. As long as you're sticking to 7/10 laps every once in awhile, I think she'll be just fine. I can't wait to get back out there and do it again soon.
Hi
Hope you using nt01 not 5. The 5 is drag tire with horrible lateral grip. The 01 is awesome on track
41 - 49 of 49 Posts
