Just outside Madison, WI.
All the detailers I've hit up have said it's a body shop job. One body shop referred me to a different body shop due to their reputation with paint. That body shop wasn't even sure if they wanted to touch an Alfa, and even then they said it'd be a full bumper removal/respray.
As straightforward as you make fixing it sound, I seriously doubt I just wouldn't make things worse.
They’re scared of the paint. You can buy what you need for under $100, practice and still have plenty left to fix these dings.
I get it, paint feels scary because we associate it with a “forever” product once applied. Although, a practice with it, you’ll see that you can pretty much keep doing things over until it’s right, if you have the time and patience.
This isn’t a full pull and re-spray the entire bumper job. A good body shop may feel more comfortable with pulling the bumper, hanging it in their temp/humidity controlled spray room, tape, fill and feather while hanging; but them thinking this is a complete re-spray is ludicrous and frankly would turn out way worse than touching up some chunks.
You have a few options:
- Ask your local dealers if they can recommend a body shop, then go and talk with them yourself.
- Locate in your state an exotic car repair body shop.
- Or, buy a touch-up and watch some YouTube videos to learn how to minimize damage. The only problem is that the paint is so rare that you have to ask them to mix it for you. The code is located on the driver's side door frame.
Agree on all points—if you’re not comfortable with DIY, find a body shop that works on exotics. You’ll pay, no doubt, for their expertise.
And while I agree the paint is rare, it’s not impossible to replicate—or buy in a rattle can and have great results. Here are a couple of my projects with rattle can VM tri coat. The license plate frame I did in a few hours in the evening when the humidity and temps were low.
First, mid and clear coats.
On both metal and plastics. For plastic, like the bumper, I’d recommend treating with a paint adhesion promoter from 3M after a light sand.
