P0301, P0363, and P1065 errors.
15K views 26 replies 7 participants last post by  David Inc.
Daughter went to leave and called me with service engine and auto start/stop not available. When she started it, it would shake. After a few mins the idle was normal but still with errors. We went and filled up with 93 octane gas and got on it a few times. It drove normal, but the DNA selector wouldn't work. I assume due to engine codes. I just changed the oil and filter using 5.5 quarts. It would show right in the middle of the level. Today it was right next to the overfill line. I need to know which cylinder is one. I will move the spark plug from one to two and two to one and see if the error followed the plug or not. My laptop is giving me issues too that has MES on it. So I am going off the Torque app. I am including where the oil level is on the sixth bottle. Spark plugs were done 10k ago at an AR dealership about 10k miles ago.
#4 ·
I just reset the codes and is fine for now. Your thoughts on the oil level? Put in exactly 5.5 quarts, but shows almost overfilled. The car does park on an incline, but I let it idle for 5+mins in the garage and still shows high. I don't want to take off the car's diaper again lol.
#16 ·
My car has done this twice in about two months. Both times a stop, code reset and restart have fixed it, at which point it drives fine. Why it's done this I have no idea, my only thought is a failing coil pack and moisture.
Mine was at cylinder 1 as well, which would be the one to get oil splashes at an oil change, if that matters at all.
Edit: The first time it happened I had exactly the same codes as you. The second it was only P0363.
#17 ·
I want for this to not happen at all. Daughter will be going to school 2-2.5 hours away next August and don't need any of us to worry lol. If it does happen again, I will swap 1 and 2 spark plugs to see if it follows.
