41 - 60 of 63 Posts
Discussion starter · #41 ·
Finally received the exhaust valve controller from Alfissmo!! Works perfectly. This one is a new version I believe View attachment 104660 and so far the valves are open when you start the car which is nice. Could not be happier with this simple plug and play mod. This is how the car is supposed to be! Thanks again Jason at Alfissmo.
Yes this is v.2 which is upgradable if needed.
Bought one last night. Will let you know how it goes and stuff when it comes in! Thanks.
Also not sure why but you shipped it in my girlfriends little sisters name lol. Honest to god not even sure how it go on the form. I must have used auto fill or something. Its fine though as she lives with us so its coming to the right place. Just thought it was funny.
109683
Finally got the vehicle out, plugged in controller and it worked as expected. I purchased OBD extension to hide it by hood latch, however, after attaching the unit I find it isn't in the way at all.
Overall very satisfied customer and this couldn't be easier to use, highly recommend it.
Great to see a version 2.0 deliver this capability in a smaller, more compact size. I purchased the original (longer) one from Alfissimo a while back, and it's working flawlessly after all this time.
Reactions: Alfissimo
Discussion starter · #54 ·
Guys, I bought used ESC v2 from my colleague who has Stelvio QV. Will that work in my Giulia QV 2021 ? Or it is vin locked? sorry for spamming in separated post
Discussion starter · #56 ·
You need the SGW bypass too to make it work. Not VIN locked.
I just purchased one of these Alfissimo Sound Dongles V.2. I tried to install it several times and the red light just flashes seven times then stops, then flashes some more...it never turns green or activates. I emailed Alfissimo but I'm sure theyre busy with Xmas. My Giulia QV is a MY2018 with a production date of 11/2017. Any ideas. I "assumed" because of my production date that I don't have an SWG.
As you probably saw his website says manufacture date of 2/2018 and up requires the bypass. You are right next to that date. Hopefully someone can confirm that it behaves like this if you don't have a bypass. Push comes to shove I could uninstall mine to test it but Alfissimo should respond before I need to do that.
41 - 60 of 63 Posts
