DIY Oil Change + Service Interval Reset (MES)
1.9K views 3 replies 4 participants last post by  Aziz831
Hey guys, put together a full tutorial for an oil change showing how to do the service interval reset using Multi ECU Scan as well!
#3 ·
Remember to bring the engine oil to operating temperature. Even if you allow the oil to drain overnight, you need to drain the oil when it is hot, if you want to do right by your engine. Same for any other oils that you drain.
