Centerline 2.0T Sport Downpipe with Cat by Magnaflow
16K views 18 replies 9 participants last post by  JoeCab
We are excited to have our new high flow, Sport Downpipes for the 2.0T Giulia and Stelvio in stock and ready to ship.
These were developed with Magnaflow over a 2 year period, with extensive testing done on both the Giulia and Stelvio platform. We are very pleased with the results!
Our Sport Downpipe is based on Magnaflow's 5" diameter Premium 200-Cell Metallic Catalyst, which is produced in-house. This is not a cheap cat, and it features very high loading of precious metals, which allows it to flow well, effectively reduce emissions, and keep your check engine light off. It is also backed by a 5 year, 25,000 mile emissions warranty.
The first step in our design process was to perform an "autopsy" on a stock downpipe, which revealed a very restrictive 700-Cell ceramic element. Based on this data, Magnaflow felt there was significant room for improvement, while still offering a greener alternative than a "catless" downpipe.
On the road, you will feel huge improvements in throttle response and a nice, smooth power curve boost with added grunt in the mid and upper RPM ranges. In dyno testing we found solid gains and additional power was unlocked when our tuning partner Eurocompulsion created a custom tune to take advantage of the additional flow of the downpipe.
We've priced this aggressively at $989.00 and it is eligible for our free shipping offer in the Continental US.
99639
99640
99641
99642
#3 ·
There's no way to sugar coat it - this is not a particularly easy install.
You need to remove the heat shielding around the turbo, and drain the coolant, and remove parts of the cowl. Removing the factory downpipe is harder than installing the new one as it's physically larger. RWD cars have a lot more access than AWD cars.
I would definitely say "professional installation is recommended" although it could be taken care of by an experienced DIY mechanic at home.
#5 ·
There has to be a little weight savings too, which is always nice. @JoeCab any numbers on that?
owns 2018 Alfa Romeo Giulia Ti Sport Q4
#12 ·
Do we know if this vid is with the Corsa Exhaust?
If you compare it to this video with the Stock Cat and Corsa cat back:
It sounds so much cleaner with the centerline downpipe (especially if it's the same exhaust)
#15 ·
Hi @JoeCab I have one of these on order from EC. Can you advise on any measures you made to deal with thermal management/under bonnet temps.
I'm aware that the original OEM cat has a crimped on heat shield and was considering either wrapping, fabricating a heat shield, or ceramic coating the HFC before fitting.
I understand that it's good to keep the heat from the exhaust gases within the exhaust pipe down stream of the turbo, although I have also read that it could be damaging for the cat internals if they get "too hot".
What is your advise on this. Would I be voiding the part warranty if I wrap, fab a shield, or ceramic coat?
Would I be reducing the life of the cat internals?
What heat managment did you use on your development vehicle?
