So apparently....fuse is burning out due to a short .... They are working on the wiring harness.....has anyone with a Quad had to deal with this issue ?
D
D
Well that's not good. But at least the were able to confirm it was the harness. Hope they get you back on the road soonSo Norbert at Greenwich service (in Stamford) sent me this photo...He seems to think the wire was somehow damaged during manufacturing or install...
Just to add my 2 cents. I was having issues with AA, I tried a better USB cable an it started working fine. Avoid cheap cables...Not yet, but tonight I tried to enjoy a drive after work and was met with the typical phone/usb/bluetooth/Android Auto hassle. I pulled over to address it. My phone was also taking forever to reboot. I pulled the battery, replaced. It would not turn back on. Car was fine. I eventually just kept driving and tried the socket charger instead since I knew it was getting low. Was able to reboot phone, at 65%? Anyway... Couldn't get AA to connect over front main usb. (armrest does not work but lit) Working fine on media over BT. Got home and parked. Went back out to try again over usb. AA on car would flicker try to connect, display google play and my track, then say fail. It's fine on the phone (S5). THEN THE USB LIGHT on my front port on my Quad failed. It's out. Would not come back on after restarting or turning on car. I am afraid the socket failed or it's wiring. I hope like heck that pulling the cable from my phone, with it still plugged into the car usb out of frustration, didn't short it on my briefcase hardware or some other randomness in the passenger seat. My car was just inspected Monday (finally, oops!)
I am pretty bummed now because my ride was spoiled by the stupid data setting hassle you get even when things do work. Then to find the socket looks bad after 4 months and 2000 miles. Really? The car still runs and BT works at least for media but man this is annoying. On a 2018 AA and ACP were supposed to work. And the usb ports too. I guess I will schedule service but we can't seem to escape the dang winter up here.
UPDATE!
False alarm. As I sat here thinking about it, I realized I just downloaded an update for Android Auto a couple days ago. Then I deleted it and downloaded it again just to be sure I had a good install. It dawned on me, "maybe the update requires the larger form factor connector on Android phones?" I have been getting by charging my S5 with the old mini usb cord and have left the larger "double wide" usb cord in the Ferrari hooked to my Panasonic head unit because BT doesn't work on the discount Amazon buy (Why it was discounted)
I said a Hail Mary, crossed myself, (should have also asked for the intercession of St. Elegius (Eloi) of France -Patron saint of goldsmiths, blacksmiths and mechanics) went out and got the cord from Rossina and hopped into La Signora Giulia. Hit the power button and BOOM, front USB light came on (it's smart!!! after another startup) Plugged in the wide cable and phone and BOOMx2! AA works great, with media AND Google Maps. I was getting messages that maps wouldn't work on my phone at the same time before. It was fine in February when I drove to PA.
So here is my understanding: The latest update to Android Auto KILLS the old form factor cable connection and upgrades to permanent wider, newer mini usb connection (phone side) BUT they don't tell you this in a any obvious way. Or I used the newer cord on my trip and just don't remember! This is why it says it can't connect. I was going to get a dedicated cable anyway and will add one for Rossina, both in black because white looks kinda cheesy with both cars electronics.
Now I can sleep and enjoy may day off tomorrow!![]()
Where is that?So Norbert at Greenwich service (in Stamford) sent me this photo...He seems to think the wire was somehow damaged during manufacturing or install...
so your waiting for a harness?So Norbert at Greenwich service (in Stamford) sent me this photo...He seems to think the wire was somehow damaged during manufacturing or install...
Car assembly usually goes something likeso your waiting for a harness?
This looks almost exactly like my boost harness shorts on the Miata. But they were caused by vibration and shock an bad roads, and wear on the glove box edge and center console edge. Dealer and Local mechanic did not look into it. Boost engineer emailed me from Arizona that the wires I found matched the ecool injectors and no.3 cylinder which was throwing the misfire code. Ah, NO I don't need a new engine (lazy scare-dy cats). I armored my boost harness after I found and patched the shorts.So Norbert at Greenwich service (in Stamford) sent me this photo...He seems to think the wire was somehow damaged during manufacturing or install...
I always thought the larger cable on the S5 had something to do with HDMI?Also, at T Mobile, the agent said that the large cables have been discontinued! So it might have just been a bad cable afterall. i guess the newer phones are fast enough to handle all the data over the smaller plug anyway.
Thanks Woodstk. I think you are right about HDMI. I was worried about my phone too but checked it about a month ago or so. Agent just said to remember to clear the cash. And when you say they changed the connectors, do you mean back to mini HDMI/USB small plug, like the new cable I got? I have 14 days to return them.I always thought the larger cable on the S5 had something to do with HDMI?
I had (have) an S5 but ugraded to an S8 just before getting my car because the S5 was starting to get "stupid"
And just so you now, they changed connectors again.
New connecter a together. Almost like a cross between a mini HDMI and a micro USB. Can't remember what my son said they were calling it. It does seem to be a more solid connector.Thanks Woodstk. I think you are right about HDMI. I was worried about my phone too but checked it about a month ago or so. Agent just said to remember to clear the cash. And when you say they changed the connectors, do you mean back to mini HDMI/USB small plug, like the new cable I got? I have 14 days to return them.I always thought the larger cable on the S5 had something to do with HDMI?
I have USB-C on my Moto-Z. It has large pins for power on top off all that, for "turbo" charging. The big downside is that the signal pins are really short so that the connection is not nearly as reliable as with any of the others.Yup, so here is a good chart. Looks like the new USB C is flat with rounded, symmetric ends.
