1 - 15 of 15 Posts
Besides the Tint Shop in Edison, anyone else have a recommendation of a shop?
Discussion Starter · #2 ·
i ended up going to a place in new rochelle, ny called infinite tint.
they did a really nice job.
Can anyone provide some ball park numbers for the cost of getting your car tinted (and brand of tint used)?
I'm getting a wide range of estimates. From $400 for your normal tint job, to $1500 for FormulaOne (?!).
Also, any shop recommendations would be appreciated.
Thanks!
3M Crystalline which is supposedly one of the highest end films that you can get will cost about $650.
Regular 3M will go for about $275.
I went with regular SunTec which cost me $250 which is equal to regular 3M.
Where are you located?
I had mine done in New Rochelle, NY just right over the GW Bridge at Infinite Tint.
Those prices seem right in line with what I am seeing in the NW. Anywhere from $280 on up to $600 depending on the film.
I went with the Xpel Prime XR 35 and talked the installer into doing it for $575 they Quoted $600. There are going to loose more than the $25 I talked them down because they have to redo 2 windows.
Probably only 45 minutes from Jersey City.
They tint all the way to the top. Most shops leave a few millimeters which I don't like.
What % are you thinking of doing?
Here are photos that better represent the lightness of the tint.
Reactions: rav
2017 Alfa Romeo Giulia 2.0
I moved from Ohio to NJ. From what i got from the internet, we should not have any window tint for the driver side window or the front passenger side for NJ. So i removed the ceramic tint I had.
Was it a mistake? Is tint allowed for the front windows too?
Discussion Starter · #13 ·
Correct - tint is not allowed on the two front windows but I never had an issue on my Saab.
I think it also depends on how dark you go.
50% no one will ever bother you but if you go dark like 35% or darker you might have an issue.
How dark were your windows?
50% :crying:
Discussion Starter · #15 ·
you should have kept them.
1 - 15 of 15 Posts
