1 - 17 of 17 Posts
I know, the question seems stupid, but I cannot find the fuse of my USB plug located just under the climate control (see photo)
The USB is not powered anymore, nor is his backlight.
I checked one by one all the fuses in the fuse box located in the trunk and also the one located under the passenger feet.
None seemed blown.
Thanks in advance to the ones that could help me ;-)
Nice! Where did you get the chart?
Here you go:
Code:
https://www.dropbox.com/s/sfdf8v7grh8muyq/fuses_engine.png?dl=0
https://www.dropbox.com/s/kquki2hfhah5601/fuses_front.jpg?dl=0
https://www.dropbox.com/s/lkteptpu739z26u/fuses_passenger.jpg?dl=0
https://www.dropbox.com/s/z30s0e4iwowakyz/fuses_rear.png?dl=0
These are specifically for the QV, so yours may vary.
Hi Guys,
A related question for my Giuilia Veloce (2017). Does anyone know where the fuse extractor tool is supposed to be stored?
I lookedin the boot/trunk fuse box but can't see it.Can anyone confirm exactly where I should be looking?
Thanks!
Hi Guys,
Thanks!
Usually it's in the trunk fuse box. There is even place for it there
photo with fuse box, tool is at the top left corner
Je sais, la question semble stupide, mais je ne trouve pas le fusible de ma prise USB situé juste sous la climatisation (voir photo)
L’USB n’est plus alimenté, pas plus que son rétroéclairage.
J’ai vérifié un par un tous les fusibles de la boîte à fusibles située dans le coffre et aussi celui situé sous les pieds passagers. Aucun ne semblait soufflé. Merci d’avance à ceux qui pourraient m'
JOUR REMPLACE LE BOITIER A FUSIBLE ET CELA IRA MARC BERBION
1 - 17 of 17 Posts
