2281 - 2300 of 2328 Posts
2017 Giulia Ti Sport Q4
I think this is a new one:
I set one of the seat memory buttons for the position I like to use to exit the car.
I shut the engine off and push the memory button, then open the door. The seat continues to the position that I selected. I close the door.
All what I wanted to this point.
Then some while later I come back and open the door. At this point the seat unexpectedly rolls another 2 inches back.
Does your car do this?
It is called the easy exit feature. Look in your infotainment you should see an option for it. Your regular seating position may be just far enough back where it doesn't trigger normally. I had to disable the feature because it would cut off my kids legs everytime I got out.
There is no infotainment option for it in earlier model years. I think the option to enable/disable it was only added in MY19 or MY20, but definitely not @lockem's MY18.
Administrator
04/2018, 2018MY, I have that option.
My point is that I was not exiting, I was getting in. As noted by @Biscione my MY2018 does not have the infotainment disable. Honestly I like the concept of the easy exit feature, but it does not move the seat far enough to make my exit easy. IMO one should be able to set the desired exit position of the seat.
Administrator
There's a thread around here that enables it. Are you sure you didn't do it yourself? For sure it's not there by default for MY18.
I did not, and yes it is there on mine by default. I'm sure it's also dependent on seat module versions and whatnot.
In early years, easy exit was not able to be defeated. I had to get a newer CSWM module and proxi to enable the feature in infotainment. By default the car will always easy exit if you don't have the option in the infotainment.
Administrator
Yep, and I didn't have to do anything except turn it off in the Infotainment.
'18 Base Q4, white
I may need to turn this off in the near future. But...
As a former computer support person, in discussions of this sort, please supply a path to the subject. Like "Select Car, then select Settings..." Much like when I was helping a user, I wouldn't say, "Adding a printer is in Windows."
Thanks in advance.
Fogg
Administrator
Thanks in advance.
Fogg
Not quite: you can override easy exit by hitting one of the seat memory buttons. This is in part what I am doing when I see the bug in the system.
My car was built in 9/2017, so 7 months older than @JeFizz 's car.
Due to the tight leg room in the rear of Giulia, the easy exit feature really is a safety hazard. It really should not be rolling the front seat back while someone is in the seat behind.
Administrator
I pinned my son a couple of times before I found that setting. LOL
Opened drivers door at approx 3 mph and veh went into park and parking brake came on. Stupid feature.
Ostensibly, a “safety” feature.
Reactions: juancarlostv
  • Sad
Reactions: Avnyc11
