"A blowoff valve (also called dump valve or compressor bypass valve) is a pressure release system present in most petrol turbocharged engines. Blowoff valves are used to reduce pressure in the intake system as the throttle is closed, thus preventing compressor surge."It helps to maintain boost between shifts and when you momentarily lift off the throttle.
That's how it should work to avoid surging.The stock diverter valve opens wide and dumps all of the boost instantly
