The only problem with those illuminated segments is there is a program that says "at temp a° to b° display one segment". Then at temp b.1° to c°, display two segments. So a temp with half segments illuminated vs. one more than half may be 0.1° or whatever resolution the temp probe specs call for. Bottom line nothing to worry about because a digital signal is converted to an analog type display with an unknown difference between segments. A good display because you can easily see, at a glance: halfway up or a segment above or below midway, etc. A better display would combine a easy reading analog segment display with a digital temp either next to it or in the center screen between the tach and speedo, example- "149°F".
