1 - 7 of 7 Posts
Hello all my car has developed a weird noise at the bottom of the rpms under load it is like a grinding noise not sure how to explain it but it won't happen when I rev the engine when in park which leads me to believe it's something in the front axle differential area. It's a 2018 TI sport q4. Anyone have similar odd noise at low rpm
I recall you posting that you were rebuilding a Giulia - is this the same vehicle? What was the nature of the original damage? This may help with diagnosing the sound.
Rock caught between brake pad and rotor?
@Q4661 does it sound like a high pitched grinding noise that seems to increase and decrease with speed? I once had this happen and after removing the closest wheel to the noise I noticed that a small rock was stuck between my rotors. I had to use a screwdriver to get it loose. Noise gone.
1 - 7 of 7 Posts
