I looked at the Owner's Manual, and there is very little information provided for how to properly tow a QV. The only thing it says is that it must be transported on a flatbed, but no information is provided for how to put the vehicle into neutral. If the engine and electrical system is not completely dead, then I did find a paragraph in the "Care and Cleaning" section of the manual, which stated the following:
If washing the car in a service that moves the car,
for cars with automatic transmissions, PARK (P) must
be cut out. You have to shut off the engine in the
following conditions: car stopped, transmission in
NEUTRAL (N), push the starter button for at least
three seconds.
But if the engine and electrical system happens to be completely dead, this procedure will not work. In that scenario the only option would be to do what MacGeek posted. I can't believe that this information is so difficult to find. Also, I don't even know if it is possible to install the screw that MacGeek described while the car is on the ground due to the low ground clearance. I would be interested in what other's have to say on this subject.
