The hood is not designed to be closed part way. It is either up or down. I suppose to you can stuff a prop stick of some kind under it to hold it in a partially open position. Also, the hood is very flimsy, so unless the hood is down the car needs to be in a garage; otherwise wind is going to damage it.
I installed permanent cables on the battery leads. The battery leads are not all that convenient to access either, as the positive terminal has a power distribution module covering it. You can take the cap off of the power module and clip to the bolts in the power bar inside.
If I had it to do over, I would attach my trickle charger leads to the inside of the fuse box that is in the bottom of the trunk. Remove the trunk floor (it just rests in place) then remove the styrofoam block underneath to gain access to this fuse box.
I have the Alfa branded trickle charger/maintainer, which "creatively" fails to come with Alfa specific installation instructions or Alfa specific permanent wiring leads <sigh>. The low voltage lead to the charger is flat and the trunk lid can be closed on it. The AC power cord not so much. Of course if you run the low voltage leads out of the car your charger is also outside of the car, so the car had better be located somewhere that is not a problem. An alternative is to buy a flat AC extension cord.
Don't forget, if you disconnect the battery and close the trunk lid it may be a hassle to re-open the trunk lid.
