has anybody had transmission problems in any of the models?
I have a base model and the tranny sims to "jerk" back and forth around 3rd and 4rth when you slowing down and had to resume speed,
I took it to the dealer and the mechanic said "thats normal" some how I don't buy it, anybody else had this problem?
Joe,
Ti, RWD with 19" Sport Package. Having similar issues, and no, it's not normal. Alfa thought it was the transmission. Here are all my "symptoms" with the car.
Only happens once car is warmed up.
Only happens at low RPMs, from 1200-1800.
Only after you have taken your foot off the accelerator and then resume.
Happens mostly when you accelerate gradually, i.e. normal.
Happens in Automatic or Manual mode.
Car appears to "stumble" or hesitate.
This even happens if you are in cruise control, tap the brakes, let the revs fall to about 1400, and then hit "resume."
Once the revs are up, it runs well.
It has happened in every gear from 4-8.
It happens with every driver, not just me.
First time in the shop, the tech couldn't figure it out. After a couple of weeks, they called me back in to reset the transmission. Once reset, problem still persists. Car is still at the shop. An engineer who will be in town for another car will take a look at the same time.
