1 - 19 of 19 Posts
2018 Stelvio Ti Montecarlo Blue
I have a set of spare Technicos that I will be mounting my non winter tires on.
I will need a set of TPMs for them.
OEM sets are available through Mopar and other well know vendors for about $60 each or $240 + tax for the set.
I have seen some aftermarket sets available around $40 each so $160-180 a set...
Any advantages of one over the other or recommendations for a particular set?
at least make sure you get ones with the correct transmission frequency
I was wondering the same thing as I am about to order wheels and tires from Tire rack. Their tpms are $160 for the set of 4.
I ordered the same from Tire Rack and their sensors worked perfect. No programing or reset necessary. Swapped between Summer and Winter tires without a problem or TPMS warning light.
Reactions: C.Q4
I went another route and got a matching part number for the Mopar part off eBay. These worked fantastically with no issues. Here's the link:
Saved $140. Used on my winters. These are the OEM Antel parts that AR private labels, apparently.
Good deal. I had mad luck with my Porsches using aftermarket sensors. I tried the Tire Rack and they sometimes worked. It got a bit irritating.
I tried to look up the Stelvio /Giulia oem part numbers but couldn't find any verification that these matched.
The pics do look the same.
For that price, it's worth a try.
use the TireRack OEM cross to confirm or look at the MoparOnlineParts above to confirm.
108808
I ordered these this morning.
When I looked at the Mopar parts site listed above, I couldn't find alfa Romeo as an option.
If these work as expected, it's about 190 dollars in savings over OEM ❤
Discussion Starter · #12 ·
Just wanted to make sure and reply back with a huge THANK YOU!
I ordered the set off ebay, $51.67, free shipping for a set of 4 sensors that fit, perfect, paired up quickly and measure accurately.
Saved about $189 over OEM or Discount Tire and $108 over tire rack.
my pleasure to help. TY for letting us know it worked out.
I ended up paying the tire rack price but did save money by having my wheels and tires mounted and balanced as well as sensors installed when everything arrived.
Discussion Starter · #16 ·
And shipped for free - tire rack has always worked well for me over the years.
No problem with going through tire rack at all, but if we can save over a hundred bucks compared to the tire rack price, then that's good too!
1 - 19 of 19 Posts
