Haha you read my mind.Does this interfere with the parking sensors in the front?
I did Loctite Blue Threadlocker as well. Seemed like a good idea.Also, I had to use a thread locker as mine kept turning after a few weeks.
Thanks for the feedback.If it's the Alfa 9 bracket, check the mounting screws. You may need to undo them and raise it up if possible. I just tested my Cravenspeed bracket from Eurocompulsion. I can drive without it but need it for the inspection photos. The bracket is single stamp cut with a set angle tab. One bolt mount with serrated flange. I will keep it off until inspection next month. The main bolt is too short to use on my Ferrari, sadly. So I will need to buy a Ferrari type.
