I cut small squares of hardwood and plywood that fit into the saddle of my floor jack and onto the pads of my twin post lift. Hardwood for frame rails and larger flat areas, and plywood for thin rocker seams.I use hockey pucks. They're inexpensive and take a lot of abuse. Hard rubber which is ideal for this use.
Yup, me too. I made a 'special tool' out of a 4x4 so I can jack-up my 240z. It has a round notch to fit over the floor jack and is sized correctly (about 3x3) to fit under the (rear) differential. Without that extra three inches, I can't place stands under the car. Low slung racing jacks don't have much lift, so I have to raise each end twice, alternating ends to get her up high enough to crawl around. And, I have to start at the correct end or I can't get the jack under the other end.I cut small squares of hardwood and plywood that fit into the saddle of my floor jack and onto the pads of my twin post lift. Hardwood for frame rails and larger flat areas, and plywood for thin rocker seams.
Have you thought about fitting snows on less lovely wheels? You're likely to need new tires during the time you have the car, so why not make them purposeful?I wish I could use them, mine came with run flatI can't wait till those NJ winters and pot holes!
