1 - 12 of 12 Posts
So long story short, a tire shop messed up and now I need to help with a solution
-in the front 1 bolt is broken and one hole the threads are damaged
- in the back one bolt is broken and they also accidentally put one of the front bolts in the back not knowing it was longer than the backs (aftermarket rims/spacer)
So here’s where I am. I need to know if the threads can/should be repaired or if I have to replace both wheel hubs
There’s also a service parking brake warnings and brake light is blinking, I’m assuming the longer bolt in the back hit something
depends on thread damage. maybe it's enough to re-thread and bolt will hold when screwed properly with remaining 4 good bolts. even 3 bolts will hold wheel in place very comfortably, been there done that
but if you want to be safe change hubs, bear in mind hub comes together with bearing.
The threads can probably be repaired with timeserts, but there is no way I would be happy with that on my car... ..new hubs is the only proper repair
This. They need to pay for new hubs to be put on.
So I assume they just ripped into the with an impact gun did they? Does no one torque wheel bolts anymore...
I ask in advance and if I do not like the answer I go elsewhere.
The front hubs are a PITA to swap out because there is a suspension member in the way of removing one of the hub mounting bolts. At least according to the service manual, the front lower "strut" must be removed to gain access. I would not allow said incompetent tire shop to do that work.
Oh, and I would also consider changing that torx head bolt for a (grade 9?) hex head, so that the hub swap is far less traumatic next time (if there is a next time).
That sucks brother, sorry to hear that. I hope the shop will take full responsibility and take care of the situation.
I would expect that they replace damaged hub to be safe. Hold them responsible if using "repaired" hub and something happens after.
At the time of the incident the tire shop called the local dealer and asked how much the hub was. The dealer quoted them 161$ Each hub. They gave me money to go and place the order and they’d swap them out once the parts arrive.
The dealer had 1 in stock and the other I had to order. Anyways I gave the money back the next money because I could not sleep at night knowing I took money from someone else. Yes it was their wrongdoing. Yes they are responsible but in my book it was an honest mistake and they always treat me 10/10 whenever I go there. At least now they’ll be more careful !
Anyways as far as repairs go, the front hub I’ll definitely be replacing however the rear since it’s only missing 1 I’ll be getting it repaired.
Looks like they may have damaged the electronic parking brake unit. Honest mistake or not, they have insurance for screw ups so I'd take their money.
You're a better man than I. They caused a significant amount of damage to your car, which is going to cost you a lot of money to repair. Good guys or not, them paying to fix it is the right thing to do, and shouldn't affect your relationship with them.
1 - 12 of 12 Posts
