1 - 7 of 7 Posts
Looking to replace the restrictive stock air filter in your Alfa Romeo Giulia?
This is THE BEST Direct Replacement Air Filter available for your Giulia 2.0L or Quadrifoglio!
OEM paper filters present an elevated resistance to the passage of air and consequently a reduction in engine performance. Compared to a paper filter the BMC air filter permits a notably higher air flow passage, producing less than half the Pressure Drop over the paper filters. This doesn't compromise the filter's engine protection efficiency: thanks to the combination of the different oiled layers, containment of all impurities is guaranteed as far as 7 microns, while paper filters generally require total filtration of particles as small as 10 microns. So BMC air filters let more air into the engine while still protecting it better than paper ones. In addition, a traditional paper filter must be replaced regularly during routine maintenance whilst the BMC air filter is reusable and has a general life-span equal to that of the vehicle.
More information and pricing can be found on our website.
2.0L
https://madnessautoworks.com/2018-A...ir-filter-by-bmc-north-american-model-pid7082
Quadrifoglio
https://madnessautoworks.com/2018-A...-performance-air-filter-by-bmc-29l-v6-pid6670
Discussion Starter · #2 ·
This is THE BEST Direct Replacement Air Filter available for your Alfa Romeo Giulia!
BMC has a long history of manufacturing some of the best quality air filters in the world.
The principal difference between BMC oiled cotton filters and synthetic material filters (for example, plastic material cloth) is seen in the ability to retain air impurities. Synthetic filters allow the passage to particles smaller than the size of the tiny holes in the filtration material- this means that a filter with 80 micron holes allows the passage of all elements of a size smaller than the hole, only guaranteeing containment of particles larger than the dimension of the hole (for example sand has a dimension of around 50 microns). The cotton has a wider texture which*favors*a greater air-flow passage and through the combination of the different oiled layers, guarantees containment of all impurities from as small as 7 microns.
2.0L
2.9L
Only the best will do when you drive an Alfa Romeo Giulia! It was designed in Italy with Ferrari engineers after all. That is why we here at MADNESS have partnered up with BMC to offer you the single best drop-in replacement air filter for all Giulias, Quadrifoglio, and Non-Quadrifoglio!
BMC Air Filters are by far the most successful filters in every motorsports category since they equipped the champions of Formula 1, American Le Mans, Le Mans 24Hours, DTM, Superbike, AMA Superbike, and Suzuka 8Hours.
Increase the Horsepower and Torque, and Improve the Gas Mileage of your car with the very best filter on the market!
2.0L
2.9L
LOVE my filter from BMC! Does as you all said it would. Drove my Alfa to PA from AL and got excellent MPG of 33.7 and had great acceleration thru the Smokey Mountains!
Thank you for your feedback. We evaluated many filters prior to going with the BMC Product Line. We have had a very good, long term working relationship with BMC, had the opportunity to meet with the owners, spend time at their factory and see why they continue to be the leader in High End, High Quality Air Filters. There are filters that cost lest and some that cost more, but none that can match the BMC Quality, Flow Rates and Filtration. This is why we have once again chosen them to supply the new filter for our soon to be released intake.
2.0L
https://madnessautoworks.com/2018-Alfa Romeo-Giulia/alfa-romeo-giulia-performance-air-filter-by-bmc-north-american-model-pid7082
Quadrifoglio
https://madnessautoworks.com/2018-Alfa Romeo-Giulia/alfa-romeo-giulia-performance-air-filter-by-bmc-29l-v6-pid6670
Will this air filter give the car a little more roar like the cone hot/cold air intakes? Just purchased my Guilia but it’s a little too quiet compared to my Bimmer 😁
Hello CarlsGiulia,
Thank you for reaching out to us.
These hi-flow drop in air filters will give the Giulia a slightly throatier sound, but not comparable to an open intake as it retains the factory sealed intake system.
The sealed systems to tend to perform better and the filter doesn't clog as easily as with the exposed filter in the engine bay which can pull particles from all corners of the engine bay.
An intake system like our MAXFlow Carbon Fiber Intake System offers the best of both worlds as it has a Conical Filter inside the sealed carbon fiber box.
Alfa Romeo Giulia Cold Air Intake - MAXFlow Carbon Fiber Intake System w/ BMC Twin Air Conical Filter
If you would like please feel free to give us a call at 562-981-6800 and ask for Eric (ext 109) He drives a Giulia himself and has an extensive amount of knowledge about intake options for the Giulia.
Thank you again.
1 - 7 of 7 Posts
