1 - 15 of 15 Posts
NUMBER: 0808117
GROUP: 08 Electrical
DATE: August 24, 2017
No Communication with Chassis Domain Control Module (CDCM)
Some customers may notice the odometer is flashing.
Dealer will update the CDCM. .6 hours
NUMBER: 0806417
REV. A
DATE: August 3, 2017
The infamous "rear window tint" TSB
Audio System Warning Light Illuminated
OVERVIEW: This bulletin involves checking and installing a protective cover on the amplifier and verifying no corrosion to audio amp connections.
NUMBER: 0807317
DATE: August 11, 2017
Use the correct battery charger depending upon the battery type. Information only. Somewhere, somehow, Giulia batteries were probably torched during non-running software updates in which an incorrect battery charger was used.
NUMBER: 0804117
REV. C
DATE: August 4, 2017
SUPERSEDES InfoTainment SERVICE BULLETIN 0804117
REV. B, DATED JULY 18, 2017
N
OTE: This bulletin applies to vehicles within the following markets/countries: NAFTA.
NOTE: This bulletin applies to vehicles built on or before April 20, 2017 (MDH 0420XX)
equipped with one of the following radios:
• AM/FM/HD Bluetooth W/Nav 8.8 Radio (Sales Code RAN).
• AM/FM/HD W/Bluetooth 8.8 Radio (Sales Code RAP).
• W/WO Sirius XM Satellite Radio (Sales Code RSD).
• AM/FM/HD Bluetooth W/Nav 6.5 Radio (Sales Code RAJ).
• NAFTA/EMEA Standard Radio (6.5’’) (Sales Code RAG).
SYMPTOM/CONDITION:
Some customers may experience one or more of the following:
• Navigation takes too long to recover after losing satellite signal.
• Certain Android phones have reduced BluetoothT functionality.
• Display is stuck on black screen.
• Display frozen on Alfa Romeo logo.
• Radio intermittently reboots.
• Oil level displayed on the ETM is incorrect.
• Autoplay
does not maintain “ON” status after the network goes to sleep.
• Park Assist Module (PAM) graphics stayed on screen even after dismissing via Rotary Pad.
• Loss of favorite contacts.
• Lane Departure menu option available in a vehicle without the lane departure warning option.
In addition, the following improvements are included:
• Radio station preset bar updated to include seven presets and a shortcut to the rest of the
presets.
• Radio menu updated to show frequency, stations names, and favorite numbers.
• Remove kilohertz (KHz) and megahertz (MHz) and show frequency in figures.
• Show three alternative navigation routes, instead of just one.
• Reduce Point Of Interest (POI) categories and show address, phone number, and direction.
• Improve location input for navigation routing.
• The zoom feature on navigation map can be accessed without changing menus.
• When using navigation guidance, more details will be given on the next turn, exit number,
street name, and complete address.
• Numbers are larger on the touch screen when dialing.
• Improved speech for navigation.
• Maps update.
• Update to BluetoothT device compatibility.
• On Menu, the 9Apps9 icon will be changed to “Car9 icon.
• Show phone info instead of phone repetition.
• Show navigation info instead of navigation repetition.
• Show audio info instead of audio repetition.
• Optional routes like GoogleT maps.
• When changing tracks, the album art does not change to match the current song/track.
DIAGNOSIS:
If a customer’s VIN is listed in VIP or your RRT VIN list, perform the repair. For all other customers
that describe the symptom/condition listed above, perform the Diagnostic steps below.
NOTE: If the ETM software version is MV002.008.041, only the ETM will have to be updated.
1. Check the ETM software version.
2. Start the vehicle and turn on the radio.
3. Press the “MENU” button that is next to the Rotary Pad, to activate the main menu.
4. Turn and press the Rotary Pad to select and activate “SETTINGS” mode.
5. Turn and press the Rotary Pad to access the “SYSTEM” function.
6. Turn and press the Rotary Pad to access the “SOFTWARE UPDATE” function.
7. Turn and press the Rotary Pad to access the “CURRENT SOFTWARE” function.
0804117
REV. C 28.
What is the ETM software version?
a. MV002.008.041, only update the ETM. Proceed to Step 1 of the Repair Procedure.
b. MV001.011.020, update the ETM, Navigation, and Owners Manual. Proceed to Step 1 or
the repair procedure.
c. MV002.009.043, ETM has the latest available software. Use inspection LOP (186002NN)
to close the active RRT.
NUMBER: 0806917
DATE: July 27, 2017
SYMPTOM/CONDITION:
Some cars the remote start does not always work. Upon further investigation
the technician may find the following Diagnostic Trouble Code (DTC) has been set:
• B105213
Remote
Start Antenna Circuit
Open.Update Body Control Module software. Reset TPMS sensor programming.
NUMBER: 0806517
DATE: July 22, 2017
SUBJECT:
Exhaust Gas Recirculation (EGR) Temperature Sensor Inspection
OVERVIEW:
This bulletin involves inspecting the EGR temperature sensor for cracks and possibly replacing it.
MODELS:
2017 (GA) Alfa Romeo Giulia
NOTE: This bulletin applies to vehicles within the following markets/countries: NAFTA.
NOTE: This bulletin applies to vehicles built on or before March 03, 2017 (MDH 0303XX)
equipped with a 2.0L 280HP I4 DI Turbo Engine (Sales Code EC2).Inspect and replace sensor as necessary. Visual inspection must be confirmed.
Continued to next post...
Discussion Starter · #2 · (Edited)
NUMBER: 0806017
DATE: July 14, 2017
This is an RRT for sold and un-sold VIN's. (Rapid response transmittal- dealers *should update the vehicle prior to delivery if applicable)
NOTE: This bulletin applies to vehicles built on or before June 05, 2017 (MDH 0605XX) equipped with a 2.9L 505HP V6 BiTurbo
Engine (Sales Code EED) or equipped with a 2.0L 280HP I4 DI Turbo Engine (Sales Code EC2).
SYMPTOM/CONDITION:
Vehicles or customers may experience a Malfunction Indicator Lamp (MIL) illumination with
Diagnostic Trouble Codes (DTCs) that cannot be cleared. Upon further investigation the technician
may find that one of the following DTCs have been set:
• C140186
WheelSpeed Plausibility Failure Signal Invalid.
• C141C86
Video Camera Private CAN Communication Failure Signal Invalid
Fix: Update ACC module software to latest
NUMBER: 0806217
DATE: July 15, 2017
NOTE: This bulletin applies to vehicles built on or before May 09, 2017 (MDH 0509XX) equipped with the Harman Kardon Premium Audio System (Sales Codes RCA).
SYMPTOM/CONDITION:
The customer may notice poor audio quality or one or more of the following Diagnostic Trouble
Codes (DTCs) may also be set:
• U200387 Message Status Lbss From Left Blind Spot Sensor Missing Message.
• U200487 Message Status Rbss From Right Blind Spot Sensor Missing Message.
• U200587 Message Haptic1 From Body Control Module Missing Message.Fix: flash amplifier module with latest software. WiTech required for diagnosis.
Verify AMP software level, If software versions 3.07 or 3.09 are present it is necessary to replace the amplifier.
NUMBER: 0900517
REV. B
GROUP: 09 Engine
DATE: August 22, 2017
SUBJECT: 2.0L Coolant Hose ORing Replacement
OVERVIEW: This bulletin involves replacing the O-ring on the turbocharger coolant return hose.
MODELS: 2017 (GA) Alfa Romeo Giulia
NOTE: This bulletin applies to vehicles built on or before January 13, 2017 (MDH 0113XX)
SYMPTOM/CONDITION:
The customer may experience a small coolant leak from the O-ring seal of the turbocharger coolant
return hose.
DIAGNOSIS:
If a customer’s VIN is listed in VIP or your RRT VIN list, perform the repair. If any vehicle not on the
VIN list exhibits the symptom/condition, perform the repair.
Incorrect slightly leaky O-ring on left, correct O-ring on right with more girth.
NUMBER: 1803017
REV. C
GROUP: 18 Vehicle
Performance
DATE: July 14, 2017
THIS BULLETIN SUPERSEDES SERVICE BULLETIN 1803017
REV. B, DATED JUNE 09, 2017.
Stalling upon restart of the vehicle after re-fueling? Phonic sensor re-learning can be an issue. The list of trouble codes from the flywheel/timing position is extensive..
THIS SERVICE BULLETIN IS ALSO BEING RELEASED AS RAPID RESPONSE TRANSMITTAL
(RRT) 17043.
ALL APPLICABLE SOLD AND UNSOLD RRT VIN’s HAVE BEEN LOADED. TO
VERIFY THAT THIS RRT SERVICE ACTION IS APPLICABLE TO THE VEHICLE, USE VIP OR
PERFORM A VIN SEARCH IN TECHCONNECT. ALL REPAIRS ARE REIMBURSABLE WITHIN THE PROVISIONS OF WARRANTY.
FOR HELP WITH USING wiTECH FOR ECU FLASH REPROGRAMMING, CLICK ON THE
APPLICATION’S “HELP” TAB.
THE wiTECH 2 SOFTWARE IS REQUIRED TO BE AT THE LATEST RELEASE BEFORE
PERFORMING THIS PROCEDURE.
SUBJECT:
Flash: Powertrain Diagnostic and System Improvements
OVERVIEW:
This bulletin involves reprogramming the Engine Control Module (ECM), also known as a
Powertrain Control Module (PCM) with the latest available software.
NOTE: This bulletin applies to vehicles within the following markets/countries: NAFTA and
**LATAM.**
NOTE: This bulletin applies to vehicles built on or before **May 10, 2017 (MDH 0510XX)**
equipped with a 2.0L I4 DI Turbo Engine (Sales Code EC2).
SYMPTOM/CONDITION:
Customers may experience a Malfunction Indicator Lamp (MIL) illumination. Upon further
investigation the technician may find one or more of the following DTCs have been set:
• P045500 Evaporative Emission System Leak Detected (Large Leak).
• P0087 Fuel Rail Pressure Too Low Bank 1.
• P2172 Throttle Actuator Control System Sudden High Air Flow Detected.
• P0171 System Too Lean Bank 1.
• P0236 Turbocharger/Supercharger Boost Pressure Sensor Performance.
• P0363 Misfire Detected Fueling Disabled.
• P1CEA Boost Side EVAP Purge System Performance.
• P250B Engine Oil Level Sensor Circuit Performance.
• P0139 O2 Sensor Circuit Slow Response Bank 1 Sensor 2.
• P015A O2 Sensor Delayed Response Rich To Lean Bank 1 Sensor 1.
• P0440 Evaporative Emission System Incorrect Flow.
• P0441 Evaporative Emission System Incorrect Purge Flow.
• P0002 Fuel Quantity Regulator 1 Control Circuit Performance.
• P0244 Turbocharger/ Supercharger Wastegate Solenoid “A” Range/Performance.
• P062A Fuel Pump “A” Control Circuit Range/Performance.
• P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature).
• P0514 Battery Monitor Module Temperature Monitoring Performance.
• P2AC0 Intake Air O2 Sensor Reference Voltage Circuit Range/Performance Bank 1.
• P0402 Exhaust Gas Recirculation “A” Flow Excessive Detected.
• P2B89 Intake Air O2 Sensor Circuit Low Voltage.
• P0456 Evaporative Emission System Leak Detected (Very Small Leak).
In addition, customers may experience the following condition:
• Stall upon restart after refueling.
Fix: Update ECM software. If not performed correctly, the phonic P1300 flywheel sensor learning will stay "active".
NUMBER: 2103217
GROUP: 21 Transmission and Transfer Case
DATE: July 13, 2017
SUBJECT:
Flash: Transmission Shift and Driveability Enhancements
OVERVIEW:
This bulletin involves reprogramming the Transmission Control Module (TCM), with the latest available software.
MODELS:
NOTE: This bulletin applies to vehicles built on or before May 02, 2017 (MDH 0502XX)
equipped with a 2.0L I4 DI Turbo Engine (Sales Code EC2) and 8 Spd Auto 8HP50
Trans (Sales Code DFW).
SYMPTOM/CONDITION:
Customers may experience a bump or jerk type feeling when the vehicle starts to move after a
Stop/Start event.
Fix: update TCM software with latest
NUMBER: 2303717
REV. A
GROUP: 23 Body
DATE: September 23, 2017
SUBJECT:
Odor Coming from Engine Compartment
OVERVIEW:
This bulletin involves replacing the cowl seal gasket and sealing off the two vent holes in the hood.
MODELS:
NOTE: **This bulletin applies to vehicles built on or before February 28, 2017 (MDH
0228XX)**.
SYMPTOM/CONDITION:
Customers may notice a smell in the passenger compartment while operating the vehicle in traffic conditions (Stop and Start, 2nd and 3rd gear and parking maneuvers).
Fix: apply insulating tape on hood vent holes and replace cowl gasket
NUMBER: 2303817
VIN's prior to: 0405XX
Glovebox door and latch are replaced as new unit. Original latch would definitely break if the Giulia manuals were forced inside and the door was forcibly closed.
10 pounds of manuals in a 5 pound box? Yes, Alfa Romeo will replace your glovebox door. Alternately the manuals can be stowed in the inflator spare tire area of the trunk.
NUMBER: 2400217 REV. A
GROUP: 24 Heating and Air Conditioning
DATE: July 14, 2017
THIS BULLETIN SUPERSEDES SERVICE BULLETIN 2400217,
DATED APRIL 13, 2017,
WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE HIGHLIGHTED
WITH **ASTERISKS** AND INCLUDE CONVERTING THE BULLETIN TO AN RRT, INCLUDING
ADDITIONAL STEP, FAILURE CODE STATEMENT AND INSPECTION LOP.
**THIS SERVICE BULLETIN IS ALSO BEING RELEASED AS RAPID RESPONSE
TRANSMITTAL (RRT) 17058.
RRT VIN’s HAVE BEEN
LOADED. TO VERIFY THAT THIS RRT SERVICE ACTION IS APPLICABLE TO THE VEHICLE,
USE VIP OR PERFORM A VIN SEARCH IN TECHCONNECT. ALL REPAIRS ARE
REIMBURSABLE WITHIN THE PROVISIONS OF WARRANTY.**
SUBJECT: Flash: HVAC Diagnostic and System Improvements
OVERVIEW: This bulletin involves reprogramming the Heating Ventilation Air Conditioning (HVAC) Module with new software.
LATAM.
NOTE: This bulletin applies to vehicles built on or before March 21, 2017 (MDH 0321XX).
SYMPTOM/CONDITION:
Some customers may notice the following issues with the HVAC/Comfort system performance:
• Rear defrost is deactivated during a Stop/Start operation.
• Heated seat function first command sets to the minimum level and the button needs to be pressed three times to reach the maximum level.
Software enhancements include:
• Heated seat function first command will now set to the maximum level.
• Stop/Start operation is disabled when the rear defrost system is on.
• HVAC fan speed will increase during a Stop/Start operation.
Cool. Glad to see that the navi updates were released to the mass market. This should make it easier for anyone with the old version. If anyone cares, YES its worth the time taking the car to the dealer to get the navi update.
Thanks Eric! :D
2017 Ti Q2
Much appreciated.
Tipo 33 Stradale 1/18 scale
i think i might have a turbo cooler O ring leak
my secondary reservoir was almost empty and i see traces of pink goo around near where the turbo is (right hand side all the way down the side to the barge board can see pink )
luckily spotted and have refilled both reservoirs and watching for any drop in levels ... all seems good
wondering if i can control the leak by not pushing it hard until it gets replaced, dealer is waiting on parts
What antifreeze did you use?
The factory fill is Petronas Paraflu UP with a Fiat Spec 9.55523 and a Chrysler spec MS.90032
Reactions: JuliaQ4-Nut
it was given to me by a dealer, it should be about $10 US
Maybe $10. a quart, plus shipping, if you can find it.
So the dealer "gave" it to you.
Did they top it up, or give you the fluid to refill yourself?
Was it in a Petronas container? What size bottle?
1 quart = 1.665348 pints (UK) or 0.208169 gallons (UK) or 0.946353 Liter so its a volume unit of measure in the US
1 - 15 of 15 Posts
