NGK LKAR8BHX replaced at 20k miles. Mine looked similar to yours.Which model did you use? What interval did you use for plugs replacement?
Also experienced smooth idle after you changed them?NGK LKAR8BHX replaced at 20k miles. Mine looked similar to yours.
Yes. I also datalogged my car since I wanted to make sure the gap was correct and there wasn't any spark blow out. 0.7mm seems like such a wide gap for a car that runs 20psi...but it was happy all the way to redline.Also experienced smooth idle after you changed them?
