1 - 4 of 4 Posts
Good afternoon. Is there any information available on safest top speeds where I could still shift between all modes? Example... I was on freeway conserving fuel in ‘Advanced Efficiency’ mode and wanted to switch to ‘Race’ mode. Is that ok to do at any speed or does it need to happen below a certain speed?thankyou
shouldn't matter at all. it just changes the mapping. it normally stays in the same RPM/gear you were in prior to the change and any inputs (throttle, gear changes, etc) after the fact will be based on the new mapping. Some cars when you select sport mode will automatically downshift for more aggressive driving, ours will change modes and be ready to respond accordingly.
^^what he says, you can switch whenever you like as many steps as you like, depending at what you are doing with throttle or brakes etc car responds immediatelly and smoothly, no hickups, delays etc
Thank you for the input!
1 - 4 of 4 Posts
