Hmm......i tried that and it does not seem to work, maybe i did something wrong, will fiddle with it later.Split screen is one of the options; to turn it off got to:
Settings/Infotainment/Splitscreen and choose OFF
I read the owner's manual last night and looked thru all the settings and could not find where you can make it full screen. I am going to the dealership tomorrow and will ask but I have a feeling that you won't be able to make it full screen.Ok, it must have just been my imagination.. shame, as the view is so small.
Eric,Would be nice for a software mod to allow the full-screen for the reverse camera. Add it to the list:
1. Boost gauge
2. Oil Temp
3. Trans Temp
4. Rear view cam full screen
Thank you! There was a setting for the backup camera that had to be changed to add a delay to it turning off when you shift back into drive. Once I changed the setting it stays on. Good work around.The only "work around" would be to put the car in "reverse", then back in "drive" and pull into your garage while the camera stays on for a short period of time.... That's what I do when needed - although it is a bit of a chore to come to a complete stop, and go thru the procedure to see the camera view behind...
