1 - 20 of 22 Posts
I do not know what the situation is with this car but during my lunch break I figured I tried to redline the car. The car wouldn't do it. N Mode or A Mode the car doesn't run up to spec. Next week I have a visit to the dealer because I have been having some issues with acceleration stumbling, I was reading on the forum here that some had problems with injectors. If an injector is faulty, will it throw a code? Because right now I do not have any CEL.
I had no trouble red lining mine. I can't believe you are having so much trouble. Hope it all works out.
Thanks hopefully it will work out, I have a visit to the dealer and it may even happen by Friday. Last week, you should have seen the engine trying to gain speed but being dragged down as it was stumbling into 70-80mph. Something is not running right.
Hi SerpenteRosso,
Sorry to hear about this! Please don't hesitate to send us a PM with any questions or concerns that may arise during your dealership appointment, we're happy to assist if needed.
Andrea
I already have a case # for over a month and a half, I'm not happy at all.
Hi SerpenteRosso,
Andrea
Hi SerpenteRosso,
Sorry to hear this! I was able to locate your VIN in our private messages and have further documented your concerns in your case and alerted your Case Specialist to reach out to you as soon as possible.
Andrea
Don't put your faith in ARC. I had a case number and dealer appointment and never heard from them again. They must have a heavy case load. You've had nothing but trouble from the beginning.
Me neither I think the problems could be the following: coil packs, a possible vacuum leak, spark plug or plugs, or injectors. The car doesn't run the way it was engineered to do.
Is this a new issue on top of your other ones or is it on going? You should start a case for them to buy it back.
The car is in the shop may be fuel delivery related. Hopefully it's figured out.
Discussion Starter · #12 ·
Next week the engineer is going to look over the car they can't figure it out
You tried to redline the car in N or A mode. Were you in auto mode or manual?
Discussion Starter · #14 ·
Both the car is not running as designed. Tried the D mode and N in both auto and manual mode no difference. The car has a misfire which they cannot seem to solve.
Wow, sorry to hear.....
Discussion Starter · #17 ·
Monday the engineer is taking a look at this car hopefully they can figure out the performance issues. All concerns verified by the tech...keep ya'll posted
Please post which model Giulia that you own.
You could include this information in a signature line, so that you don't have to type it every time. :)
For your sake I hope it gets resolved. Through all the problems with your car you have never said anything bad about Alfa. You are a true Alfista. Good luck Monday and can't wait to shake your hand at a Sunday breakfast.
1 - 20 of 22 Posts
