I guess it still moves too fast for my liking when stopped if it does slow down. My Lexus comes to a complete stop.
Anyway, I have not been successful in setting the wipers to the "service" position. Any insight on that?
Right there in the user manual-
Windshield Wiper
Raising The Windshield Wiper Blades ("Service Position" Function)
The "service position" function allows the driver to replace the windshield wiper blades more easily. It is also recommended to activate this function when it is snowing and to make it easier to remove any dirt deposits in the area where the blades are normally positioned, when washing.
Activation Of The Function
To activate this function disable the windshield wiper before setting the ignition device to STOP.
This function can only be activated within 2 minutes of cycling the ignition to STOP.
To activate this function, move the lever upwards for at least three seconds.
If, after using the function, the ignition is set back to ON with the blades in a position other than rest position (at the base of the windshield), they will only return to rest position following a command given using the stalk (stalk upwards, into unstable position) or when a speed of 3 mph (5 km/h) is exceeded.
Replacing The Windshield Wiper Blades
Proceed as follows:
1. Raise the wiper arm, press tab of the attachment spring and remove the blade from the arm.
Windshield Wiper Stalk
Function Deactivation
The function is deactivated if: More than two minutes passes
before cycling the ignition to the STOP position after having raised the lever and putting the wipers into service position.
