That's the sensor. When looking at the engine its on the left side. the piece sits on top of a "seat" for lack of a better word. IF that sensor isn't seated 100% correctly it throws the CEL and puts the car in limp-mode.So are there two of these crankcase pressure sensors? The code avnyc and a few others posted about earlier was just “crankcase pressure sensor” but the code Kuffs and I have is “crankcase pressure sensor b.” Or is just some separate issue with the sensor / sensor reading?
I looked around under the hood and found this sensor on the left side but nothing on the right. P04DB Crankcase ventilation system disconnected, FIX
I do expect it to go off again, but I didn’t think you could clear codes with an OBD scanner in Alfas after some point in 2019 or so. I thought it required the SWG bypass. Does it have to do with the type of code? Extent to which it is “cleared,” if there is such a spectrum?I was also able to clear the code the second time the CEL popped up as instructed by my service advisor. I didn't think I would be able to clear it either but it worked temporarily for some reason. I was able to drive in D mode for a little bit the next morning but the code went off again later that day.
If I eraseSo they are ordering a PCV valve or tube to replace first. They said that is the first thing to try for the P2C33 code then there is a much more complicated algorithm for the P2c34 code.I was always able to clear my P2C33/34 code on my 2021 Stelvio QV even when it was listed as permanently stored. If I just kept pushing clear on my $15 Amazon OBD reader it would eventually clear. The problem is that it would come back. Sometimes in a week sometimes a month. As I wrote above after 125+ days Alfa just lemoned the car. No one ever figured out how to fix it. Many parts were replaced. Some guy was even “flown in” to investigate and he couldn’t figure it out either.
Sounds like a lot of vehicles from 2020 on are having this issue. Hope they figure it out. When I clear it, it comes back in one or 2 starts but seems to last longer when the dealer clears it (I’m sure past the SWG is more durable). Mine just goes to N so not a big deal as long as it is fixed before track days in the springI was always able to clear my P2C33/34 code on my 2021 Stelvio QV even when it was listed as permanently stored. If I just kept pushing clear on my $15 Amazon OBD reader it would eventually clear. The problem is that it would come back. Sometimes in a week sometimes a month. As I wrote above after 125+ days Alfa just lemoned the car. No one ever figured out how to fix it. Many parts were replaced. Some guy was even “flown in” to investigate and he couldn’t figure it out either.
It seems like some people have had this resolved but your experience is definitely concerning. Any similar issues at all with your 2023?I'll try to find my paperwork but IIRC, first they changed the sensor itself, then PCV valve, then PCM, then wiring voltage checks or something then maybe the wiring harness but I'm not sure, then they gave up.
My 2023 is fine....so far. For my 2021, the problem popped up around ~4500 miles (right now Im at around 3000 with the new one). I drive 15,000 miles per year so "inactivity" is absolutely not a cause of my problem. Also, my battery was fine the whole way through so I dont think it was a low voltage issue.It seems like some people have had this resolved but your experience is definitely concerning. Any similar issues at all with your 2023?
We did indeed!@graymatters I think we actually discussed this on the stelvio forum via PM right?
I wonder about that too. CEL first appeared during a downpour. Second one in a drizzle. Both during colder temps. Seasonal issue?Oh one last thing (I know, I'm long-winded): when my sensor WAS pulled the tech said there was "a lot" of moisture in the area. Always wondered if just a strong rain or strong puddle caused a short somewhere and this is why the issue never went away.
I really hope they figure this out. I don't want a new car. I love my seats and the green/white stitching across the dash, doors, etc. I like my setup. Wouldn't be the same.We did indeed!
Hope your 2023 remains problem free. FWIW my dealer has two 2022 plus my 2021 with this issue at the moment.
