Had a close call last year on Dennytown road for those who know Putnam Valley.
2 factors about that day, 1: it was warm, about 50F; 2: I was going over a hill that also has a curve in it. I was in D and must have been about 3/4 throttle. I don't think I was fully straight at the crest which was my fault, but I'm wondering if the warm (warm for winter) weather exacerbated things.
Don’t know the area but sounds like a scary experience. My most confident miles on my QV are actually on these same Alpins, and they seem to grip the same in all temps.
The Alpins will lose grip but are controllable when they do. I’ve put at least a thousand miles on them in race mode and the biggest issue I have with them is a bit of mushiness in steering response at the center.
My recommendation would be to find an abandoned/remote parking lot and learn the limits of the tires and car - I did this and it made a big difference in helping me understand the limits.
In race mode, 1st gear:
1. Drive in a circle (about a 1/8 - 1/4 turn away from full lock) at low speed (<30 MPH). Gradually modulate the throttle so you slightly lose and regain traction - this will give you a good feel for where the limit is
2. Same as #1, but floor it momentarily while circling - the car will spin out. This is a terrifying but useful exercise to understand what total traction loss feels like in a safe area
3. Same as #1, but keep accelerating gradually so the car begins to drift; attempt to keep it in a drifting state as you circle, then apply additional throttle and steer out of the circle into a straight line skid until the tires grab hold and propel you forward. This will most closely resemble the limits you might hit when encountering unexpected loss of traction on the road. You should be able to regain traction when this occurs with careful steering and throttle modulation (abrupt movements are your enemy)
In D mode, 1st gear:
4. Same as #1, but full throttle the entire way around the circle - the car should remain completely in your control as ESC intervenes to modulate the power of the vehicle.
This gave me tremendous respect for the power of the car and the capabilities of the tires - this is not a toy and I still plan to take it to a professional driving school in the spring or summer to get better at understanding its limits.
You may also want to double check that the tread wear on the tires is within its useful life.
Be careful and stay safe.
