341 - 360 of 366 Posts
Does anyone have experience fixing repairs with Fidelity warranty. Talked to dealer again questioning non-OEM and using. after market parts in repair. He said dealer always use new parts and OEM with Fidelity warranty. There is some confusion. I only have 11 days to decide whether to keep Fidelity or switch to Mopar.
Does anyone know apart from Mopar, original Alfa Romeo OEM warranty.... (another dealer was mentioning this, if you want OEM parts)?
Considering the aftermarket on the car in non existent I wouldn’t worry about switching. They not gonna throw an aftermarket differential in. Or after market trans, fuel pump etc. You have limited part choices. 99.9% are going to be OEM on a QV.
Thank you for replies.
This is what I see under Fidelity warranty website. This is for Platinum Coverage. I also took brakes, battery, locks, and tires coverage warranty. What is missing from Platinum coverage, is there any other warranty that covers?
Platinum Coverage
In addition to offering the same features of Powertrain and Gold, Platinum expands to cover many assemblies of your vehicle, giving you the "Ultimate Peace of Mind" protection. Certain restrictions, limitations and/or exclusions may apply.*
PLATINUM IS EXCLUSIONARY COVERAGE:
This means it covers your vehicle’s assemblies unless listed under the Exclusions section of the Vehicle Service Contract.
PLATINUM EXCLUSIONS:
Brake linings, brake drums and rotors, disc brake pads, standard manual transmission clutch friction disc, pressure plate, pilot bearing, throw-out bearing and arm, air bags, solar powered devices, glass, lenses, sealed beams, body parts and/or panels, weather stripping, trim, moldings, lock cylinders, tires, wheels, all batteries except Hybrid/EV/Hydrogen High Voltage batteries as listed under Gold Coverage, light bulbs, upholstery, paint, bright metal, freeze plugs, filters, heater and radiator hoses, exhaust system, catalytic converter, shock absorbers, work such as front-end alignment or wheel balancing (except when required in conjunction with a mechanical breakdown), safety restraint systems, audio/security or other systems not factory installed, or vinyl and convertible tops.
Platinum Coverage
THESE ARE THE EXCLUSIONS FROM THE MOPAR MAXCARE PLANS:
THE PLAN WILL NOT COVER, OR APPLY TO LOSS OR EXPENSE RESULTING FROM:
• Repairs or replacement of any component covered by any of the Vehicle manufacturer warranties, Certified Warranty, part manufacturer warranties or recall policies; roadside assistance, loaner vehicles or other services which are eligible to be covered by the Vehicle’s manufacturer warranty or marketing programs;
• Repairs required as a result of other than a manufacturing defect (such as a design defect or normal wear);
• Repair or replacement of any covered component when it has been determined that the condition existed prior to
purchasing the Plan;
• Plan benefits where the Vehicle odometer reading has been stopped or altered and/or the Vehicle’s actual mileage
cannot be readily determined;
• Brake pads, shoes, rotors and drums are not covered at any time (regardless of cause of failure);
• Reimbursement of services/benefits that exceed the total number of services/allowance included in Plan Coverage;
• Battery and cables; any battery for a component; spark plugs and wires; lights (bulb, sealed beams, lenses);
suspension alignment; wheel balancing; wiper blades; catalytic converter, particulate filter and any other exhaust system components; heat shields and exhaust hangers; throttle body cleaning; evaporator deodorizing; carbon cleaning;
• High voltage battery is not covered at any time (regardless of cause of failure);
• Repairs due to any alterations or modifications to the Vehicle not approved or recommended by the manufacturer,
including but not limited to: (a) failure of any custom or add-on / aftermarket part (unless listed as a specific covered
part); (b) emissions and/or exhaust systems modifications; engine modifications, transmission modifications, and/or drive axle modifications, which includes any performance modifications; (c) oversized/undersized tires; (d) all frame or suspension modifications; (e) aftermarket lift kits; (f) Mopar lift kits (unless you have purchased this coverage as shown on the first page);
• Lift kits that exceed four (4) inches unless you have purchased Mopar Lift Kit Coverage as shown on the first page; repairs to covered components that are the direct result of the failure of a lift kit that exceeds four (4) inches unless you have purchased Mopar Lift Kit coverage as shown on the first page;
• Repairs to covered components that are the direct result of the failure of alterations or modifications not recommended by the manufacturer;
• Plan benefits necessary as a result of (a) failure to properly care for or maintain the Vehicle; (b) fire, accident, abuse, vandalism, negligence, Acts of Terrorism or Act of God including but not limited to the Vehicle rendered inoperable due to snow, ice or flood; (c) failure to properly operate the Vehicle; (d) Vehicles that have been used or are being used for competitive speed events such as races or acceleration trials; (e) pulling a trailer that exceeds the rated capacity of the Vehicle or failure to adhere to the requirements for vehicles used to pull a trailer as outlined in the owner manual supplied by the manufacturer; (f) tampering with the emission system or with any parts that could affect that system; (g) use of dirty fluids, or fuels, refrigerants or other fluids which are not recommended by the manufacturer; (h) failure due to fluid contamination or sludge; (i) modifications not approved or recommended by the manufacturer; (j) overloading rated payload capacity of the Vehicle; (k) damage incurred by off-road usage; (l) rust, salt, corrosion, overheating, water intrusions/leaks, acid rain, chemicals, tree sap, hail, flood, lightning, fire, windstorm, earthquakes or other environmental causes or acts of nature;
• Fasteners, bolts and attaching hardware that does not attach a covered component to another covered component;
• Repairs to a covered component where the component has been restricted by the manufacturer; repairs that are the
direct result of the failure of a component that has been restricted by the manufacturer;
• Repairs caused by pre-ignition detonation, pinging, improper/contaminated fuel including fuels containing more than
10% ethanol (if the engine was not manufactured for this mixture);
• Plan service obtained from other than a Dealer unless authorization is first received from us. FCA US Vehicles must
return to a FCA US LLC Dealer for Plan covered repairs; (Dealers cannot authorize repairs.)
• RepairsrequiredasaresultofuseofotherthantheVehiclemanufacturer’spartsduringthetermofthe
Plan, unless authorized by us;
• Repairs to a covered component caused by the failure of a non-covered component and/or an aftermarket installation
not performed by a Dealer, or any outside installation of "salvage or junk" components in conjunction with an insurance or damage claim. All part installations to satisfy such claims must be with new or factory authorized remanufactured components and parts;
• Bodily injury or property damage arising or allegedly arising out of a defect in the design, manufacture, materials or workmanship of a covered component;
• Any fines, fees or taxes which are associated with impound towing as a result of actual or alleged violation of any laws or regulations;
• Plan benefits to Vehicles operated outside of the United States, Canada, Guam, Puerto Rico and Mexico;
• Plan benefits to Vehicles registered outside of the United States, Guam and Puerto Rico;
• Exterior - tires; trim; name plates; appliques; body sheet metal; glass; plastic lenses; paint; bright metal; bumpers;
side-view mirrors (glass/ housing); wheel covers; steel wheels; aluminum wheels; rusted or frozen rims; weather strips; rust; water leaks; restricted drain tubes; wind noises; all outer body panels; spoilers; plastic and fiberglass body parts; vinyl tops; convertible top fabric; repairs or damage caused by environmental factors such as acid rain, tree sap, salt or ocean spray;
• Interior - trim; carpet; upholstery; dash pad; door and window handles; knobs; buttons; moldings; arm rests and head liner; cargo cover; cosmetic appearance; torn/worn/soiled;
• Mechanical - manual clutch assembly; clutch disc, pressure plate, clutch release bearing and pilot bearing (manual transmission); damage to flywheel as a result of a clutch failure; repairs to snow plows, winches and trailer hitches regardless of their installation;
• Cost or expenses for teardown, rental, inspection or diagnosis of failures not covered by the Plan;
• Shop supplies, waste disposal fees and materials;
• Repairs to any Vehicle where the title has become branded or the Vehicle has become restricted by the manufacturer
after the purchase of the Plan;
• Maintenance services specified in the owner’s manual and the parts used in connection with such services;
not performed by an authorized Dealer;
• Repairs or replacement to components covered by the Hybrid System Limited Warranty (refer to Warranty booklet for
details);
• Hybrid components: hybrid charging system; hybrid electric cooling system; hybrid power inverter system;
• Portable Units including but not limited to - headphones; I-Pods; GPS units; DVD players; laptop computers; cellular
phones; any hand-held device; Navigation DVD; spare tire compressor and tire sealant;
• Repair or replacement of Performance parts, Performance enhancing parts, repairs to covered components that are the
direct result of failure of a performance part (except for parts pertaining to lift kits if you purchased Lift Kit coverage as
• Any economic loss of any kind, including but not limited to rental car expenses, consequential damages, incidental damages, or other losses that relate in any manner to your use or loss of use of the Covered Vehicle.
Lot of confusion here on term of lease. Original warranty from date in service. You can extend that warranty during the first 36 months and the extension will be from the original in service date. After 36 mos the Mopar warranty will run from the date of purchase of the warranty.
Jeff
My QV is a 2018. I original warranty is up Feb. 28th, 2023. I have 15.3K miles in almost 3 years of ownership (bought a Alfa fleet car with 265 miles in 1/2019) so I put about 5K miles per year. So in 8 years or 2027 I will have 40K mile estimated. I know the OEM parts are ultra expensive and it makes sense to get a Mopar extended warranty but which warranty makes sense base on my usage? Just wondering if anybody is in the same boat and what path was chosen and why.
I would get the max warranty and get the highest number of years with the lowest mileage based on your usage
Reactions: Alfissimo and mikeg
I am in the same boat...2018 QV with 9600 miles so far and warranty ends in 12/22. No issues so far so wondering if and which (how much) warranty makes sense.
Definitely IF
You should get a warranty for the piece of mind
As to which, well the I would suggest the max care, and then pick the miles/years that match your usage then buy whichever fits your budget.
Plus if you sell the car, then you can sell the warranty
Reactions: mikeg and Alfaraff
Holy heck. Just got Ziegler quotes for '19 QV. 8/125:
Deductible:
$ 0: $12,465.00
$100: $ 8,490.00
$200: $ 6,975.00
What do they know that we don't? Now that FCA has several years worth of actual data on warranty claims, I suppose this should't come as a surprise. It's the actuarial equivalent of Margo Channing saying "Fasten your seatbelts. It's going to be a bumpy night"
Or does it also reflect the reality that in the last few years folks simply aren't turning in leases and replacing cars as often as they used to so there's going to be increased claims AND a higher demand for extended warranties -- why not charge as much as they can, while they can?
Deductible:
$ 0: $12,465.00
$100: $ 8,490.00
$200: $ 6,975.00
What mileage do you have? I would also call Mopar directly
The car I'm considering this for has under 1k miles. Here's the Fidelity Platinum quote from Troy Dietrich which he confirmed is for QV but I remain skeptical:
With $0 deductible:
5 yr / 60K - $2587.00
5 yr / 100K - $3879.00
6 yr / 60K - $2858.00
6 yr / 100K - $4178.00
7 yr / 70K - $3452.00
7 yr / 100K - $4648.00
8 yr / 80K - $4119.00
10 yr / 100K - $5291.00
With $100 deductible:
5 yr / 60K - $2352.00
5 yr / 100K - $3345.00
6 yr / 60K - $2713.00
6 yr / 100K - $3655.00
7 yr / 70K - $3220.00
7 yr / 100K - $3889.00
8 yr / 80K - $3679.00
10 yr / 100K - $4436.00
With $250 deductible:
5 yr / 60K - $2106.00
5 yr / 100K - $3177.00
6 yr / 60K - $2480.00
6 yr / 100K - $3414.00
7 yr / 70K - $3055.00
7 yr / 100K - $3700.00
8 yr / 80K - $3428.00
10 yr / 100K - $4190.00
Deductible:
$ 0: $12,465.00
$100: $ 8,490.00
$200: $ 6,975.00
You waited until the last minute so it's going to cost a lot. I bought mine under 12k Mike's it was the 7 year 80k for $4100. It's expensive but just think if you threw a rod or need a differential replacement the warranty would be paid for hand over fist.
This is correct. Currently I see more aftermarket coming but at this point it will be suspension parts and filters. Some misc. parts will be available but it will be mostly OEM.
With $0 deductible:
You can just say you have 25k miles. They don’t check.
With $0 deductible:
Under 1k should be the lowest cost but these prices seem in line. I think I paid 4200 for 200 ded and an extra 3/35k but this was at 22k
yeah, the Fidelity Platinum seems the way to go. Had it on an Audi S8 and was worth its weight in gold to me, AND the subsequent owner of the car.
Try calling Mopar directly though. I bought my car warranty from clay Robbins because he was the cheapest until I called Mopar to ask about my wheel warranty and turns out you can buy directly from them and they sell at cost.
Reactions: Umizoomi
