1 - 4 of 4 Posts
Hi,
Does anyone know if the LSD that comes with the performance pack can be fitted to a standard (that is: open diff RWD) Giulia without too much hassle (driveshafts, diff casing, software, ...)?
And am i correct in assuming this is a Quaife torsen diff as is the Q2 available for the 147,156,GT, etc.?
My understanding is that the 4 cylinder lsd is mechanical.
The 6 cylinder lsd is electronic.
Reactions: 2-eleven
ZF it is...
Hi,
Rear diff is ZF HAG RDU with Mechanical multiplate clutch option. I believe this rear is entirely mechanical, without any need for electronic control. The aftermarket catalog is available on the ZF support site.
https://aftermarket.zf.com/go/en/aftermarket-portal/technical-information/catalogs/pdf-catalogs/
Hope this helps,
Reactions: WCL21 and ybba
1 - 4 of 4 Posts
