the sub woofer is located right in the middle of the rear of the Car. For the cars with the base stereo, If you look inside your trunk you will see an opening in the sheet metal already pre-cut where the sub woofer would normally go. It will be very easy to install an aftermarket sub woofer with the dimensions. The installer will need to cut a hole in the material inside the cabin. I would also recommend to purchase an amplifier as i dont think the base radio has enough wattage to power a sub woofer or any additional speakers for that matter. Thankfully the car battery is in the truck so an installer can easily plug an amplifier and feed it power.Can anyone post pictures of the subwoofer for the harman variant? (Inside the trunk)
I have a base audio system, so i would like to know how and where the stock subwoofer would fit?
You read my mind. Considering the fact that the trunk space is small, i was wondering if I could use the opening where a stock sub would have been installed. I may be way off here, but that opening is around 6.5 inches?the sub woofer is located right in the middle of the rear of the Car. For the cars with the base stereo, If you look inside your trunk you will see an opening in the sheet metal already pre-cut where the sub woofer would normally go. It will be very easy to install an aftermarket sub woofer with the dimensions. The installer will need to cut a hole in the material inside the cabin. I would also recommend to purchase an amplifier as i dont think the base radio has enough wattage to power a sub woofer or any additional speakers for that matter. Thankfully the car battery is in the truck so an installer can easily plug an amplifier and feed it power.
The speaker layout for the three different sound systems is below so you can see the difference between the base, upgraded 400 watt system and the 900 watt HK sound system.
i would recommend you use that space. By placing an open/free air subwoofer in the original location, it will use the trunk space instead of a traditional box enclosure thus saving you a lot of space. Not sure of the dimensions of the pre-cut hole howeverYou read my mind. Considering the fact that the trunk space is small, i was wondering if I could use the opening where a stock sub would have been installed. I may be way off here, but that opening is around 6.5 inches?
You're giving me ideas about a "Spinal Tap" special edition Giulia.Thats the reason why i want to see the subwoofer. I have seen 8,10,12 inches subwoofer but no idea about this 7x8 size
Thats the sub? Am really sorry for people who opted the premium audio setup.Here are a couple of quick snaps of the subwoofer (HK). I don't have a tape measure right now but if you need exact dimensions I can get them later today.
No idea what it is (You're giving me ideas about a "Spinal Tap" special edition Giulia.
You're forgiven for not knowing. A fun movie you might enjoy. Speakers galore.No idea what it is ()
Here is what I had installedi would recommend you use that space. By placing an open/free air subwoofer in the original location, it will use the trunk space instead of a traditional box enclosure thus saving you a lot of space. Not sure of the dimensions of the pre-cut hole however![]()
The shop that installed my aftermarket system said the factory sub was the cheapest one they had ever seen, they estimated it cost less than $20.00The factory sub is pathetic, and I don't think it even has a dedicated amplifier.
....and they all go to 11!!!!You're forgiven for not knowing. A fun movie you might enjoy. Speakers galore.
Nice! dual JL Audio? what exactly did they install? (additional amp?) you mind giving us approx. cost?Here is what I had installed
thanks!
...speechlessNice! dual JL Audio? what exactly did they install? (additional amp?) you mind giving us approx. cost?
thanks!
Focal BE Utopia Ultima 3 way fronts
Focal 2 way 165 rears
Audison Bit One HD processor
2 JL Audio HD amps
JL Audio TW5v2 subs
Dyna Matt sound proofing through out
20k ish
wow!focal be utopia ultima 3 way fronts
focal 2 way 165 rears
audison bit one hd processor
2 jl audio hd amps
jl audio tw5v2 subs
dyna matt sound proofing through out
20k ish
