Those are accurate. Roll into the throttle in 4th and you'll see 27-28. On launch in 1st and 2nd I see max of like 22-24 I think.Bump,
On map 2 JB4 I’m seeing my peak boost at 25/26 on the app. I’ve seen it once hit 27. This seems to not be normal... also, how can I edit map 6? It doesn’t let me in the app.
I would hate to be leaving any power behind that I could add.
So I could theoretically make map 6 the strongest one? Like just put 30 psi of boost?Those are accurate. Roll into the throttle in 4th and you'll see 27-28. On launch in 1st and 2nd I see max of like 22-24 I think.
You edit map 6 in options.
Youd get limp mode just doing 30 psi across the board. You have to get familiar with the turbos oost curve and request just over what it can make. Request any more than that and the car will think its underboosting and throw a code and limpSo I could theoretically make map 6 the strongest one? Like just put 30 psi of boost?
Ah, I see. I’ll probably end up sticking with map 2 for now. Definitely disappointed about E85 and map 3, and not knowledgeable enough to mess with map 6. I’m hoping they actually introduce the water/meth map and the mod itself. Would love to get 350-400 whp from the car if possible without upgrading the turbo (if even possible)Youd get limp mode just doing 30 psi across the board. You have to get familiar with the turbos oost curve and request just over what it can make. Request any more than that and the car will think its underboosting and throw a code and limp
Map 2 is the best option to run. They also did a recent update to make it more consistent and reliable. Unfortunately, all the tuners pretty much maxed out the potential of the platform in it's current form. The only way to achieve the 400hp mark is to make a big turbo kit, but the cooling system is also a limiting factor. The intercooler is pretty much mounted internally and seems impossible to upgrade in any way. I doubt it has the cooling capacity to handle such a big power leap.Ah, I see. I’ll probably end up sticking with map 2 for now. Definitely disappointed about E85 and map 3, and not knowledgeable enough to mess with map 6. I’m hoping they actually introduce the water/meth map and the mod itself. Would love to get 350-400 whp from the car if possible without upgrading the turbo (if even possible)
Also if you try to get too much boost out of the turbo you run the risk of overspinning the turbine. If done in moderation that will just reduce the turbine life expectancy and overall engine efficiency. If done in the extreme the turbine can fly apart rather violently.Youd get limp mode just doing 30 psi across the board. You have to get familiar with the turbos oost curve and request just over what it can make. Request any more than that and the car will think its underboosting and throw a code and limp
The stock cooling system is doing fine with hybrid turbo but for full frame big turbo sure it might need upgrade. This is very very simple and cheap to do adding another heat exchanger up front. The ic brick itself is usually the last thing youd touch.Map 2 is the best option to run. They also did a recent update to make it more consistent and reliable. Unfortunately, all the tuners pretty much maxed out the potential of the platform in it's current form. The only way to achieve the 400hp mark is to make a big turbo kit, but the cooling system is also a limiting factor. The intercooler is pretty much mounted internally and seems impossible to upgrade in any way. I doubt it has the cooling capacity to handle such a big power leap.
Where can you see this?
