Sorry if this has already been covered...
The P button seems awfully vulnerable to being hit while underway, causing a major transmission detonation, and I can imagine possibly selecting R, as well. The Giulia guide and manual don't really address this, other than issuing dire warnings about not engaging P or R except when stopped and the foot is on the brake.
So I asked Miller Motorcars, my dealer. Here is their response (short answer is, no, you can't shift into P or R at speed):
>>You cannot put the car into Park above about 2 MPH. Reverse, I believe is higher, maybe 3 MPH. Both are disabled above those speeds. The shifter is purely electronic (“Shift by Wire”), and there is NO mechanical connection between the shifter and the transmission, so there is no way to accidentally put the car in Park or Reverse while driving above 3 MPH. Below is specific technical information you can review.<<
TRANSMISSION SHIFTER
DESCRIPTION
A significant innovation is represented by the shift-by-wire shift engagement control, which means:
• There is no mechanical connection between the transmission and the shift lever.
• The shift lever is a device that detects the driver’s requests.
• There is no mechanical backup.
• The hydraulically actuated parking lock is managed by the Transmission Control Module (TCM).
• There is always a backup device for manually unlocking it so that the vehicle can be moved if necessary.
Using a shift-by-wire device simplifies the control installation and assembly, improving the passenger compartment sound proofing thanks to the lack of connection cables between the transmission and the shift lever.
The transmission control consists of the shift lever and the Automatic Gearbox Shifter Module (AGSM). The TCM and AGSM both communicate on the Controlled Area Network (CAN) bus.
OPERATION
With the shift-by-wire technology the shift lever is no longer forced to follow a selection grid to achieve a given transmission condition but, not unlike a joystick, always returns to the starting position, named “Central Position”. This behavior means that the shift lever position and the gearbox condition no longer correspond. To allow the shift control to be used intuitively, a logical control system that refers to the classic R, N, D, TIP selection grid was developed. From the Central Position the shift lever may move at most two positions forwards and at most two positions backwards. The shift lever has an ergonomic design and it has three key elements built into the top for gear shift management and driver information:
• Lever release button.
• Parking lock release button.
• Transmission gear indicator.
For the following shifts, you must press the brake pedal and/or the release button:
• From P to D: Brake pedal + lever release button.
• From D to R: Brake pedal + lever release button.
• From R to P: Brake pedal + parking lock engagement button.
• From N to D: Brake pedal.
• From N to R: Brake pedal + lever release button.
• From D to N: Movement allowed without any additional operations.
NOTE:
For safety reasons, between the speeds of 2.5 km/h to 5 km/h (1.5 mph to 3 mph), it is possible to shift from R to D and vice versa without pressing the brake pedal. The D or R icon will start to flash and the gear will be engaged as soon as the vehicle speed is below the threshold of approximately 2.5 km/h (1.5 mph).
DESCRIPTION
OPERATION
NOTE:
